Door Sill Scuff Plate - DIY Upgrade and color change
Old 01-26-15, 01:45 PM
Caseoane
Caseoane's Avatar
Originally Posted by NovaRnder
Caseoane, where are you located? you can use mine to do it again for step by step photo documenting this time, Lol!!
NovaRnder... I'm in Minnesota, feel free to send them over... you are not the first one! :-)
Old 01-26-15, 01:58 PM
SlvBullet
SlvBullet's Avatar
Originally Posted by Caseoane
"food proof"?? :-)
Unfortunately, I have installed everything back in place. But if I find myself doing it with, say, someone else's sills, I'll be sure to document everything...
I'll post new pictures. I should have the strips in a couple of days.
Old 01-26-15, 02:31 PM
Caseoane
Caseoane's Avatar
Good luck!
Old 01-26-15, 10:37 PM
texsexlex
texsexlex's Avatar
Keep us posted texsexlex... And learn from my mistakes: careful with scratching the OEM light if you cut from the back. Good luck!
...if & when I get them, I'll definitely pm you to get some more details to get this job done
Old 01-27-15, 04:28 AM
Caseoane
Caseoane's Avatar
Whatever you need... let's learn from each other's mistakes... there are a couple of things I wish I had done differently.
Old 01-29-15, 08:44 PM
SlvBullet
SlvBullet's Avatar
Ordered strips domestically, tracking number shows they were delivered on Tuesday but can't find them anywhere. I guess I'll order another pair.
Old 01-30-15, 03:52 AM
Caseoane
Caseoane's Avatar
Serious? Where did you get them from?
Mine came in a little envelop from china. Easy to miss....
Old 01-30-15, 08:03 AM
SlvBullet
SlvBullet's Avatar
From
http://www.ebay.com/itm/271567931868?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
From China but they have a warehouse in CA. Shipped right away and arrived fast. I ordered another one which should arrive by Tues.
Old 01-30-15, 10:21 AM
Caseoane
Caseoane's Avatar
Good choice, they are longer than the ones I ordered - that'll make your life easier (less problem centering them).
Old 02-03-15, 12:17 PM
ShawnOk
ShawnOk's Avatar
Just got my 14cm COB lights and started test fitting and I think Caseoane is absolutely right. I highly recommend anyone undertaking this mod choose the longer 17cm light. It will def make trying to center the light much easier. Just my two cents on a fantastic write up.
Old 02-07-15, 02:21 PM
caesar400
caesar400's Avatar
Default Door lights
That's super cool. Thanks for sharing!
Old 02-08-15, 02:03 PM
theazz
theazz's Avatar
Shawn
I want to try this mod. Where did you get your new led's?
Old 02-09-15, 12:01 PM
WIL44
WIL44's Avatar
I bought the 17cm lights and did this yesterday(thanks Caseoane)
Very easy going in from the back (thanks Shawn).
Just mark out the position and cut away the plastic. I used a fine blade on a Multisaw.
Take your time and cut through the plastic until you get to the existing light. Once the piece is out remove the double sided tape with your fingers(it just rolls off) so you don't damage the white mask on the existing light. Make sure the light is a tight fit. I then taped over it with black insulating tape. Run the wire through the same holes as the existing light and solder the wires to the connector leaving the old wires where they are. Job done.
Cheers
Steve
Old 02-09-15, 12:27 PM
Caseoane
Caseoane's Avatar
Cheers
Steve
Excellent! Our legacy lives on, Shawn! :-)
Steve - what color did you use? Can you post pics?
Old 02-11-15, 12:30 AM
ShawnOk
ShawnOk's Avatar
Finished my mod! Respect to Caseoane for lighting a fire under my **** to get me to complete this mod rather than leave the spare door sill sitting in my corner behind the recliner.The light is crazy bright! Seriously blurs out the photos but def draws the attention I wanted. Already getting compliments from people and valets, I chose white to match most of the other updated LED's that are completed (and proposed later) as you can clearly tell. Glad to have this completed! Took a few shots with the new anthracite interior wrap too!
Ps... I purchased these... http://www.ebay.com/itm/251760937780?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Attached Thumbnails Door Sill Scuff Plate - DIY Upgrade and color change-img_20150209_124518.jpg   Door Sill Scuff Plate - DIY Upgrade and color change-img_20150209_124821.jpg   Door Sill Scuff Plate - DIY Upgrade and color change-img_20150209_124951.jpg   Door Sill Scuff Plate - DIY Upgrade and color change-img_20150209_125042.jpg   Door Sill Scuff Plate - DIY Upgrade and color change-img_20150209_125058.jpg
Quick Reply: Door Sill Scuff Plate - DIY Upgrade and color change
