Moog End Links, Gs300 front sway bar, Daizen Steering Bushings, and isf rear sway bar
Old 01-23-15, 01:12 PM
tennman117
tennman117's Avatar
Did you use the stock links with the isf 17mm rear sway bar or Moog ?
If Moog do you have a part # for them.
Old 01-23-15, 07:48 PM
LexBrett
LexBrett's Avatar
[QUOTE=tennman117;8881243]Did you use the stock links with the isf 17mm rear sway bar or Moog ?
If Moog do you have a part # for them.[/QUOTE
I used moog; I recalled that you used them so I bought them as well
Old 01-23-15, 07:50 PM
LexBrett
LexBrett's Avatar
But I'm not sure if I got the correct end link. There is some play with the sway bar and link. My mechanic said he put a washer over the link to fill the gap. Nonetheless could you please send me the end link part numbers you used? I used the gs300 sway bar in the front and isf bar in the rear. Thank you!
bacardi11
01-10-24 11:21 AM
416tt
06-16-15 02:51 PM
LexBrett
01-09-15 04:20 PM
ALBINO
08-05-13 09:20 AM
NYC ES3
01-07-13 12:59 AM
Quick Reply: Moog End Links, Gs300 front sway bar, Daizen Steering Bushings, and isf rear sway bar
