02 bad
Old 12-05-14, 10:51 AM
bacardi11
bacardi11's Avatar
Default 02 bad
Bank 2 Sencer 1 bad where is this sencer and how bad to install and were to buy.
Old 12-05-14, 12:30 PM
FlopTop04
FlopTop04's Avatar
Passenger side, before the catalytic converter on the exhaust manifold. Bank 2 Sensor 2 is passenger side after the catalytic converter. Bank 2 Sensor 1 is up there a ways and space is tight. Definitely need a lift. The harness connection isn't too bad because it connects to the engine harness and doesn't go inside, under the center consoled like the rear sensors do.
Old 12-06-14, 12:43 AM
V300Graham
V300Graham's Avatar
It might be that the seal between the cat outlet and the exhaust Y pipe is cracked / worn / damaged, allowing in air, with normal oxygen levels, and the engine thus thinks either the cat is not working or the sensor is kaput due to the high levels of oxygen measured.
I ran into this 6 months ago and fixed it for €3, with a new crush seal between the cat and the exhaust.
The fault will always be with the second sensor, either left bank or right bank due to this worn / damaged seal issue, so make sure which sensor is generating the error code first.
Old 12-06-14, 06:34 AM
bacardi11
bacardi11's Avatar
v300 will check that out.
did order the Denso 02 before the cat. passenger side cost me 66.00 with discount from Auto Parts Warehouse.
Old 12-06-14, 10:48 AM
416tt
416tt's Avatar
Just had mines replaced, I think it was easier then the bank 1 sensor 1. But yeah you'll need a lift.
Good luck
coug66
06-07-19 05:02 PM
vgangam
CT 200h Model (2011-2017)
07-18-16 10:32 AM
Iparkcars
04-11-16 01:35 PM
okjenny
GX - 1st Gen (2004-2009)
11-19-13 07:40 PM
geoprz
08-26-13 05:52 AM
Quick Reply: 02 bad
