Anyone install a backup camera lately?
Old 10-07-14, 09:28 PM
430keeper
430keeper's Avatar
Default Anyone install a backup camera lately?
Wondering if anyone has installed a backup camera
lately to work with the nav screen? Anyone use
Nav Tool ?
Old 10-08-14, 12:46 AM
FlopTop04
FlopTop04's Avatar
Yes and yes. Used the latest NavRGB 2.0 version of NAVTool. The actual part number was NAVRGB+TL10, which includes the correct adapter cable. There is a nice write-up / Pictorial on a 2008 SC430 on this site and the install guide provided by NAVTool is very good.
Old 10-08-14, 05:08 AM
ShawnOk
ShawnOk's Avatar
NAVIKS is another company and I'm very happy with my results. They were also very helpful via the phone for any questions I had during my install and the instructions were spot on.
Old 10-08-14, 06:05 AM
Habious
Habious's Avatar
I've done a couple of the NavTool installations.
My own, plus JohnnyCakes (the old version).
He started have some intermittent issues with his recently, and we ended up swapping it out with the new version of the NavTool. Fundamentally the same but, the newer one is a bit nicer, and better made.
Both are straightforward installations.
Old 10-08-14, 02:39 PM
loveslexus
The Dog Whisperer
loveslexus's Avatar
I'm in the process of installing a camera right now....but its part of a complete stereo install.
Old 10-13-14, 10:12 PM
SlvBullet
SlvBullet's Avatar
Has anyone added the ability to turn to n the camera to see the rear while driving? Like using the rear view mirror but close to eye level - would make a quck check less distracting when at track speeds.
Any ideas on how to do it with a switch or something?
Old 10-13-14, 10:31 PM
FlopTop04
FlopTop04's Avatar
With the current model NAVTOOL, you could connect another rear view camera to the Video 1 input and use the push button switch to select Video 1. This second camera could be adjusted for a different / better rear viewing angle. You would also have to ground the NAVTOOL's Gray Parking Brake input wire for Video 1 to function while on the track.
If you install the NAVTOOL push button switch, you can use the switch to select the car's Nav screen input as per this info from the NAVTOOL's install guide :
Operating NavTool interface via push button:
Single push will cycle between Video 1 and Video 2, press and hold push button for more than 2 seconds to return back to the original navigation/information screen. Aftermarket camera can be easily viewed while driving by installing push button, no extra wiring is required.
Here is a link to the entire NAVTOOL install guide : http://www.navtool.com/manual_NAVRGB+TL10.pdf
Old 10-15-14, 08:21 PM
SlvBullet
SlvBullet's Avatar
That's awesome and worth trying.
Thanks much formthe advice. No way to use a single camera with
The two functions (in reverse or driving). The different view you mention is a valid point though - I need a further look back less angle view for the track.
Thanks again
Old 10-23-14, 05:25 PM
ktdsc430
ktdsc430's Avatar
I bought the Navisk unit a while back. However I hate to admit its still in the box. I have been to lazy to install it. Hope it works when i finally install it. I plan to hook up a front camera on the extra video input.
Old 11-03-14, 10:41 PM
430keeper
430keeper's Avatar
Where do you buy the camera itself ?
If you have the Navik interface, what
kind of camera do you look for ?
Old 11-04-14, 03:40 PM
DarthSid
DarthSid's Avatar
Conduct your search on eBay or Amazon. Most members choose the camera mounted on the license plate frame.
Old 11-04-14, 09:28 PM
430keeper
430keeper's Avatar
thanks...but i was referring to the type of camera...
what resolution ? angle of view ? day/night ? specifications ?
Old 11-07-14, 10:53 AM
DiggerJim
DiggerJim's Avatar
I bought this Boyo unit off Amazon for my backup camera.
http://www.amazon.com/gp/product/B00B4L2NCW/ref=pd_lpo_sbs_dp_ss_2?pf_rd_p=1944687602&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B001RB1U14&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=0AW2RDKJDWSXBM3TM6J2 http://www.amazon.com/gp/product/B00B4L2NCW/ref=pd_lpo_sbs_dp_ss_2?pf_rd_p=1944687602&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B001RB1U14&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=0AW2RDKJDWSXBM3TM6J2
Old 11-09-14, 07:41 AM
mandyfig
mandyfig's Avatar
DiggerJim, how was the install? Working good? Price wise compared to NAV tool? Thanks.
Old 11-09-14, 08:17 PM
DiggerJim
DiggerJim's Avatar
The Boyo camera is in addition to the NAV TL10 unit. The NAV unit just provides an interface between different audio-video sources and the stock head unit on the car so it needs input from one or more cameras and/or DVD players. The Boyo is the camera I picked to use for the camera input which goes to the NAV unit. The NAV unit plugs into the car's navigation/entertainment head controller which is located in the trunk. When I put the car in reverse the display in the dash shows the rearview camera and when it's not in reverse it reverts to normal display and turns the camera off.
You need both the camera and the NAV TL10 to get backup camera functionality.
Jim
Quick Reply: Anyone install a backup camera lately?
