Improving performance- where to start
Old 09-23-14, 09:51 PM
rlp1949
rlp1949's Avatar
I appreciate all the good suggestions. Since I'm a marginal mechanic, I especially appreciate the focus on easy fixes.
What is it about this car that makes me want to spend money on it? That has never been me. I never skimped on maintenance but had not felt motivated to go further.
The transmission pressure adjustment sounds sensible. How much of an MPG hit comes with the Sprint Booster?
Old 09-23-14, 11:14 PM
toffee123
toffee123's Avatar
The value of my '05 with 45k miles has depreciated sufficiently that it has reached the point why sell it since it looks new and runs well. Instead, it's time to mod and have some fun.
Originally Posted by LexBrett
1-Spring Booster. At about $300, this little device is magic in reducing drive by wire lag. Plus it is relatively easy to install.
Am I just paranoid or if the booster fail at the wrong time one could lost control of throttle? $300 is small enough investment but hitting a tree or off a cliff .......
2- Michelin Pilot Super Sport. If you have not already done so, taking off those run flats will completely change your car. I personally love my Michelins, although pricey at $1000.
I really like to fill up the space in the wheel well, but I don't like super low profile tires. For me rRide comfort over ultimate handling. What would be best way to go?
3. Swift Racing Technology Cold Air Intake, Chip, and heat Shield. Go to swiftracing.com and find a Cold Air kit for about $600. If the item is not listed, they do indeed make it but you may have to call. Don't expect SRT to be responsive though. They rarely answer the phone and are slow to ship. However, the Kit is amazing. I couldn't beleive the improvement in performance. These run about $600. Most people could probably do the install.
Sounded like good investment, a definite GO.
4. Magnaflow Exhaust. It's a little expensive by improves power a bit and is really fun. You can find these on Amazon for about $800.
How loud will it be? I really love the stock exhaust note, but it just need another 10db or so, so ideally for me, a somewhat louder stock, possible?
Old 09-24-14, 02:44 AM
evgeniy
evgeniy's Avatar
Is it trans mod? http://www.ebay.com/itm/Toyota-Lexus-Shift-Kit-A650-Transgo-SK-A650-/181443780495?pt=Motors_Car_Truck_Parts_Accessories&hash=item2a3ee45f8f&vxp=mtr
Old 09-24-14, 11:41 AM
ShawnOk
ShawnOk's Avatar
Originally Posted by evgeniy
That's not the modification I did. I took mine to Lexus but any mechanic should be able to do it. They drop the pan and drain the transmission fluid. Then, as shown on the diagram, there is a small pressure adjustment valve and plunger that can be adjusted. As recommended, I turned my up from min to max. Then they reattach the pan and fill the fluid again. Don't remember my cost but it was basically the same charge as a trans fluid flush. No new parts needed.
Old 09-24-14, 06:21 PM
LexBrett
LexBrett's Avatar
It's not loud at all. It's just right IMO. My girlfriend noticed too and said it sounded and looked cool :-)
I think if the sprint booster fails it goes back to stock. I have had it two years no problem but not on all the time due to drain in mpg
Old 09-24-14, 06:29 PM
LexBrett
LexBrett's Avatar
And feel free to private message if you have more questions. It has been a learning experience for me and CL has helped a lot
klimber
GS F (2016-present)
29
06-10-20 04:23 AM
bigwes
Performance
05-02-12 09:42 AM
Lex5150
08-22-07 09:05 AM
ToM_P
Performance
08-09-07 08:03 AM
Hameed
Performance
03-31-03 07:08 PM
Quick Reply: Improving performance- where to start
