Spark Plug tube seal removal and installation
Old 09-15-14, 10:10 AM
LexBrett
LexBrett's Avatar
Default Spark Plug tube seal removal and installation
I found oil on my spark plugs. A chat with the guy at advance auto parks indicated this is because my spark plugs tube seals are leaking. After some internet research I found a 'seal removal tool' that looks like it may be appropriate for removing the seals. I guess the impact of the oil on the plug is reduced mpg?
Has anyone successfully replaced these seals? Is it difficult? What took did you use and how did you prevent debris from dropping in there as you were digging for the seal? Lastly, what are the risks of the DIY job?
Old 09-16-14, 06:47 AM
kjcole
kjcole's Avatar
I'm also noticing a little oil in a few plug wells and suspect tube seals. Anyone changed these? Pictures? I'm used to old engine designs where the plug screws right into the head without passing through valve covers etc, unlike newer designs using coil-packs and so on.
Old 09-17-14, 10:07 PM
texsexlex
texsexlex's Avatar
I haven't done this personally, but my mechanic did mine when he changed my valve cover gaskets. I'm not 100% sure, but i think you have to remove the valve cover to get to them. If I remember, I'll give him a call tomorrow & see if this is correct
Old 09-18-14, 03:36 AM
LexBrett
LexBrett's Avatar
I'm positive there is a tool for this without having to remove the valve cover (what a pain ). I'm going to advance auto today to verify and I will let you know! Thanks!!
elejes
05-11-19 08:10 AM
931UZFE
Performance & Maintenance
13
06-20-17 06:33 AM
Jbthompson
09-09-15 08:00 PM
eknine9
12-24-14 10:59 PM
2muchpsi
12-01-07 07:47 PM
Quick Reply: Spark Plug tube seal removal and installation
