Pillar removal and reset
Old 07-16-14, 05:29 AM
leighv
leighv's Avatar
Default Pillar removal and reset
Hi all,
My front drivers side pillar is flapping around and won't stay in the set position. It seems to be the washer that the one of the clips goes into (at the very bottom of the pillar) has corroded.
So firstly I am trying to take it off - but after reading the removal of windscreen instructions I see:
21. REMOVE FRONT BODY PILLAR ASSY OUTER RH
a) Remove the nut.
I can't see a nut and if it's under the pillar how do I access it?
And then
34: INSTALL FRONT BODY PILLAR ASSY OUTER RH
a) Exchange the clip with a new one
What clip is this referring to and what is the part number.
Many thanks.
Old 07-27-14, 03:16 AM
leighv
leighv's Avatar
Anybody please?
Old 07-27-14, 10:43 AM
ShawnOk
ShawnOk's Avatar
Could you possibly provide some photos?
Old 07-28-14, 02:49 AM
leighv
leighv's Avatar
Hopefully this might make a little clearer?
Attached Thumbnails Pillar removal and reset-2014-07-28-10.14.58.jpg   Pillar removal and reset-2014-07-28-10.15.21.jpg   Pillar removal and reset-2014-07-28-10.16.09.jpg
Old 08-04-14, 12:30 AM
leighv
leighv's Avatar
Anybody? Everytime I am on the motorway I have to bang the pillar back into place - several times..... Cheers.
Old 08-05-14, 08:40 PM
007's Avatar
i had issue with my pillar.. it has multiple clips to hold it in place and it is screwed in at the top.. you will need to order those clips from the dealer.. for small pieces of plastic they aren't cheap. If you're on the road i suggest using a good tape to tape it down or some 3M/Scotch extreme 2 sided tape rated at about 15-25lbs to hold it in place
wsrivers
08-31-18 11:47 AM
Michael3L
RX - 3rd Gen (2010-2015)
07-21-18 12:36 PM
hsmac
RX - 1st Gen (1999-2003)
34
02-17-16 10:07 PM
taeng
08-29-07 09:00 AM
XSTeknique
SC- 1st Gen (1992-2000)
01-20-07 09:36 PM
Quick Reply: Pillar removal and reset
