Transmission locked in park
It happen again for the second time in a few weeks. I popped the little cover and pressed the override which worked fine. I am curious if there is an adjustment or if this portends thinks to come?
Curiously, has this happened on a hill whereby you have let the car roll a bit after putting the car in park before using the parking brake? If so, this puts tremendous strain on the pin that holds the car in park and makes it extra hard to remove it from park.
Nope, both times on flat and level. 1st time was morning in my garage and the most recent flat and level at my office when I left for home! Nothing has changed in my habits.
Don't see an answer
Same thing happening to me with my '02 SC430. Level in the garage, and on 3 occasions recently Trans locked in Park. Solenoid?
foot on brake,
hand off shifter
start engine
place in reverse
is it possible you are applying pressure to the shifter before you press the brake pedal?
Transmission lever normally won't come out of its Park position unless your foot is on the brake causing the transmission lever locking mechanism to release. I'd agree that first item to check is the brake sensor switch. The switch should activate a solenoid that moves the trans lever locking mechanism out of the way so the trans lever can be moved past Park position. I'd pull the console top cover off the next time it happens and see if the unlock mechanism is being triggered when the brake is applied.
SC430Dad (11-24-22)
jdanielca
08-26-18 11:07 PM
