Hi1 New to the Forum I have a strange issue!
Old 07-14-14, 01:34 PM
gooffeeman
gooffeeman's Avatar
Exclamation Hi1 New to the Forum I have a strange issue!
Greetings everyone!
My name is Carlo I am from Palatine Illinois a suburb of Chicago! I recently acquired a 2004 SC430, and the radio did not work. I purchased the radio kit from beatsonicusa.com and a kenwood DNX571HD. After the install was complete on the radio I also replaced the stock sub with a Polk Audio 840 DVC. But since the stock amp can not handle a dual voice coil set up, I am just running 4 ohms to the amp. But the issue I am having is the radio reception in the car. I knew I had install an aftermarket antenna since the stock antenna is data controlled. I put in a Metra 44UA20 which is an amplified antenna. I have the antenna mounted in the rear deck of the car behind the seats. So the antenna is "outside" when the top is down. With the top up or down, I get really bad reception. I tried plugging in the stock antenna plug with no success either. But when I take my metra antenna 2 feet up in the air or outside the car, I get great reception. Anybody have the same issue? does anyone have any ideas to what is causing this reception issue? I have a tire pressure sensor light on and the dealership told me that all 4 of the senor batteries are dead. Could it be that they are emitting some type of radio interference?
Thanks for Looking!
Old 07-14-14, 02:14 PM
MDames2
MDames2's Avatar
Not sure what you reception problem is. But if your sensor batteries are dead, I can't imagine they would be emitting anything.
Old 07-14-14, 02:15 PM
mrblister
mrblister's Avatar
Are you talking about FM reception. If so FM channels work best at different heights of the antenna. The OEM antenna goes up and down depending on what channel you are tuning to. It does this automatically to get the best reception.
AM channels in my sc430 do not work well at all. In fact I find this to be so in all of my other cars. Years ago AM stations had more power that could explain why the dont perform well now
AM is amplitude modulation and FM is frequency modulation. Thats why the antenna works at different heights for FM
Old 07-14-14, 02:16 PM
bacardi11
bacardi11's Avatar
I use the polk 840 with focal1 amp to power the sub alone.
Old 07-14-14, 02:33 PM
gooffeeman
gooffeeman's Avatar
I under stand FM signal works better in heights. But why do I get great reception outside of the car perpendicular to the rear deck or better yet out 2 feet away same height as the door. BTW AM or FM
Old 07-14-14, 02:54 PM
mrblister
mrblister's Avatar
I cant explain it have you tryed a regular antenna not amplified with a booster
Old 07-14-14, 06:17 PM
gooffeeman
gooffeeman's Avatar
I just bought one at BestBuy....no success.
cep89
GX - 1st Gen (2004-2009)
10-16-21 07:34 AM
HDH
03-12-18 07:49 AM
boxcarfan
GS - 1st Gen (1993-1997)
08-19-10 09:51 AM
JRGS400
02-22-09 12:59 PM
Quick Reply: Hi1 New to the Forum I have a strange issue!
