The S2000 antenna is in
Old 06-30-14, 12:53 PM
mandyfig
mandyfig's Avatar
Default The S2000 antenna is in
Finally found the time to install the antenna and get rid of the telescope. No loss in reception. Finally!
Will post pics soon.
Old 06-30-14, 12:57 PM
mandyfig
mandyfig's Avatar
1st pic. Have some DIY photos. Not hard at all. Looking for caven speed mini antenna, I think it will look better. For now it is the s2000.
Old 06-30-14, 01:41 PM
mcgene
mcgene's Avatar
Looking forward to the pics and description of installation.
Would love to get rid of mine as well.
Have one on my RX300 and hate it! My wife has a LS430 and the antenna is in the windshield (I think). Love that.
Old 06-30-14, 01:43 PM
Lexeffect
Lexeffect's Avatar
Can't wait mandyfig... Show us! Show us!
Old 06-30-14, 02:52 PM
mandyfig
mandyfig's Avatar
Here are some pics
Attached Thumbnails The S2000 antenna is in-ant1.jpg   The S2000 antenna is in-ant2.jpg
Old 06-30-14, 02:56 PM
mandyfig
mandyfig's Avatar
My favorite radio stations are coming strong.
Old 06-30-14, 03:07 PM
mandyfig
mandyfig's Avatar
I ordered the Craven Speed Stubby, let's see if it looks better. If it does not, it goes to the Miata!
Old 06-30-14, 06:08 PM
ShawnOk
ShawnOk's Avatar
Looks great Mandy! Wish you had taken photos of the antenna before the install so we can see the connection end and a step by step install. What did the antenna run you? Did you have to remove the entire motor, or is it still in place? It looks as if it the speed stubby has a much wider base so it might not fit without fender modification. Great work so far though!
Old 07-01-14, 04:51 AM
mandyfig
mandyfig's Avatar
I do have pics to show how I modified my antenna to fit our SC.
To start with (just because these were available for me) and you can source this now:
Celica Antenna, or perhaps any Toyota antenna base.
Honda S2000 Antenna, if you like this style. This antenna fits the base perfectly.
The hardest part is the full tear down of the trunk. If you take your time, it is just a bunch of clips and bolts. You will tear down the right side to access the antenna.
The Antenna is 1 piece. Take out the bolt and the whole thing comes off, after disconnecting the power.
For my Celica base, I had to cut out a portion of the base (the white base where the antenna mounts) since the trunk of the antenna was shorter than the original, I cut out about a quarter of an inch.
Then it is simple as screwing in the retainer bolt.
To add rigidity, I took the frame off the old antenna and mounted it back and tie wrapped the base, in case somebody wanted to steal the antenna, they can not.
I have a business trip, but will bring the pics with me so I post here.
I am so happy the outdated look is gone.
I want a lot of people to get a chance to do theirs.
1-5, 5 being the hardest, this is a 3.
I know that fleabay has a ton of the S2000 antenna, as well as the antenna base.
In a previous thread, I posted the base I had.
Old 07-01-14, 04:56 AM
mandyfig
mandyfig's Avatar
Here's my original thread on the antenna conversion:
https://www.clublexus.com/forums/sc-...onversion.html
Lots of basic info.
Old 07-01-14, 05:33 AM
mandyfig
mandyfig's Avatar
Well I know a lot of you want to dig into this quickly, so here are the pics showing the DIY. Take your time, collect all clips, nuts and bolts. The clips are easily taken out by using 2 screw drivers. Allow a few hours to get this done.
Old 07-01-14, 05:35 AM
mandyfig
mandyfig's Avatar
Take your time in putting the whole trunk back together. The DVD NAV and the Amp are available for mods while the trunk is wide open.
Old 07-01-14, 09:32 AM
Lexeffect
Lexeffect's Avatar
Looks great mandyfig! Well done sir. I have to agree with ShawnOk on the Craven Speed antenna. The base of that particular antenna looks a bit to wide. Perhaps we will be proved wrong. Either way, nice mod and thankyou!
Old 07-01-14, 04:59 PM
SlvBullet
SlvBullet's Avatar
Thanks much for this Mandy. I have a TRD CF stubby antenna so I only see to find the Celica mast right?
Why do you plug the drain hole?
Old 07-01-14, 06:53 PM
SrWilliams
SrWilliams's Avatar
Mandy:
That was one heck of a write up and instructional. The whole zip tie and use of the original base kind of lost me but I am hoping I will figure it out
Quick Reply: The S2000 antenna is in
