Trans Service
Old 10-02-14, 06:46 AM
LexBrett
LexBrett's Avatar
Hi All;
Is the dial to turn to the right depicted by the green or red arrow in my attached picture? THANKS
Old 10-02-14, 08:03 AM
bacardi11
bacardi11's Avatar
that the one and its set on the third setting all done.
Old 10-02-14, 08:29 AM
NAmVet68
NAmVet68's Avatar
Originally Posted by LexBrett
Hi All;
Push the one with the Green arrow in and turn all the way to the right (clockwise) for firmest setting. Easy.
Biggest headache is cleaning up the mating surfaces for the pan gasket (use a NEW gasket or you will be sorry!).
Old 10-02-14, 11:30 AM
LexBrett
LexBrett's Avatar
This mod looks very doable. I will have to do this on my back though with ramps and carefully placed jack stands. I assume I need to use OEM Toyota Fluid (WS Grade)? If OEM ATF is not available, do you have any other suggestions? Is it 5 or 6 quarts to refill through the dipstick after dropping the pan? I'll make sure to buy to a new gasket!
Old 10-02-14, 12:03 PM
toffee123
toffee123's Avatar
Any downside or consequence in doing it? Should i understand that by making this adjustment, it won't change the slow throttle response but will making the down shifting a bit quicker?
Old 10-02-14, 12:04 PM
toffee123
toffee123's Avatar
So just turn the green arrow and not to touch the red?
Old 10-02-14, 01:54 PM
NAmVet68
NAmVet68's Avatar
Yep, just push in and adjust the "Green" screw (it's called the "Primary Regulator Valve" in the diagram), don't mess with the Red valve. According to Talwang's diagram (post #12), that's the lockup control valve....
https://www.clublexus.com/forums/sc-...0-a-650-e.html
Old 10-06-14, 06:41 AM
Autoplak
Autoplak's Avatar
I ask toffee's question again as I'm seriously considering this.
No tranny noise while driving? Any gas mileage change?
Or just a great positive mod.
I'm torn between that Lexus factory set to soft, however they allow adjustment assuming that firm does no tranny damage.
Old 10-06-14, 06:57 AM
bacardi11
bacardi11's Avatar
just do the mod you will have no trouble at all. its all to the good. MPG will go up also.
this is a happy camper mod.
Old 10-06-14, 08:13 AM
iolmaster
iolmaster's Avatar
The question Autoplak asks is still valid. If this is such a good mod. Why does Lexus have it in the soft position? Not saying your are wrong. Just would like to know the answer.
Old 10-06-14, 12:36 PM
bacardi11
bacardi11's Avatar
they must want the shift as soft as possible this is the thinking of all car companies to get a soft shift the trans must slip only way. a trans that shift fast is better for the trans that's why they have shift kits for all trans. fast shift less ware. most people would not like a shift kit in their cars. I have rebuilt many trans in my day. that's the best ans I can give you. when I raced my vett. it would almost bang in to gear. well done up shift kit.
just so you all know this is not a shift kit mod.
Old 10-07-14, 03:12 AM
JETII
JETII's Avatar
Is everyone going to the firm or medium setting?
Old 10-10-14, 10:37 PM
SlvBullet
SlvBullet's Avatar
I did the firm and am happy with the it shifts and feels.
Old 10-11-14, 07:41 AM
toffee123
toffee123's Avatar
I asked and show them the printout of this thread, but the local Lexus dealership refused to do it
Old 10-11-14, 08:03 AM
bacardi11
bacardi11's Avatar
toffee
go to your local trans shop and have your trans fluid change and filter and have him do the mod for you. go's to show you the techs no nut thing about it.
Quick Reply: Trans Service
