Garage door opener
Garage door opener
My 07 SC430 did not come with an owners manual, so I have printed pages from the online manual as needed. I have printed the section that gives instructions for programming the garage door opener. I am not able to get this feature of my car to work. Holding in the button does nothing and I do not get the indicator light as mentioned in the instructions. What am I missing? I have tried a search on this sight for some discussion on this topic but was not able to find help.
You can call Homelink customer support directly for assistance. They are the experts.
1-800-355-3515
Call them from a cell phone while sitting in your car and they will walk you through programming.
Remember, you first need to program the car to clone a working remote. Once that is done you need to program your garage door device to learn the newly programmed car button.
After you program the hand held opener to the homelink unti, you need to get on a step ladder and press the "learn" or "smart mode" button on the back of you garage door motor bolted to the ceiling. After you press this button, you will have 30 seconds or so to run back out to the car, and find the homelink button that you programmed earlier. Press it for 1 second, release it, press for 1 second and release it. Continue doing this until your door starts opening and closing.
Thanks for all the help. I'll check out the site before I call them. I'll also keep you posted on how I make out. One of the best things about owning this car is you guys always willing to help out us newbies.
One of my Garage remote just died and it time for my lazy *** to set it to SC.
I have a small garage and the SC sit right under the door motor. Its impossible for me to press the learn/smart button unless I move the SC half way out the garage. If I do that and follow the above instruction....will the door shut on the SC? Can this be done with the SC outside of the garage?
That was very helpful!!
Go to YouTube.com and search for Toyota homelink for video directions
WARNING: In Step 2, When pushing the LEARN Button on the garage door motor just push and let go. Do not hold it in for any length of time or you will erase the programing of all other remotes previously programed.
Thanks for all the help, but I'm not able to get the home link icon to flash as is called for in the video. I'm thinking that because I'm not the original owner the 3 buttons may already be programmed and I have no clue as to how to cancel those settings. I think that it is time to call customer services.
Does it ever turn on the indicator up there? If not, maybe you have a blown fuse.
To cancel the entire memory of the unit, hold the two most outer buttons (button 1+3) at the same time for about 10 seconds, until the light flashes solid (I believe). That will erase all the stored codes. But first you must verify if the light come on at all. If not, then probably a blown fuse.
Sometimes it takes holding button 1+3 down for over 30 seconds to clear memory.
