Sway Bar
Old 09-08-14, 12:49 PM
  #121
loveslexus
The Dog Whisperer
loveslexus's Avatar
Whats the final word on the end links for the rear and front 28.5 bar?
Old 09-08-14, 02:31 PM
  #122
bacardi11
bacardi11's Avatar
if you lower the car 1" or more use the rear links ( darthsid ) used and you'll be good to go. I also used the bushings from FIG bushings that ( darthsid ) used.
Old 09-08-14, 03:22 PM
  #123
DarthSid
DarthSid's Avatar
The rear stabilizer links are 1/2" shorter than the OEM links. Just make sure you loosen the bottom bolt that holds the shock in place on the arm; otherwise you will have a very hard time removing/installing the link. These links have the correct bolt size opening as the 17mm rear sway bar.
Old 09-08-14, 03:26 PM
  #124
DarthSid
DarthSid's Avatar
The rear bushings provided by this manufacture will fit perfectly on the 17mm rear sway bar upgrade.
Old 09-09-14, 04:58 AM
  #125
416tt
416tt's Avatar
Originally Posted by ShawnOk
Can the rear sway bar mod cause the Automatic Headlight Leveling System Warning Light to illuminate on the cluster? I can't figure out what other mod could cause my light to come on and go off sporadically. As I read that the rear of the car has the headlight leveling sensors. Any help is appreciated.
Hi Shawn,
I'm not sure how much mileage your car has but could that just mean that sensor is going? Mine was doing the same thing... On and off constantly and after few months it just stopped working so I gotta replace it now. Unless you fixed the issue?
Old 09-09-14, 06:23 AM
  #126
ShawnOk
ShawnOk's Avatar
So here's my update (38,000 miles)... I changed to the recommended PU Fig bushings and while my mechanic had the car up, he checked the headlight sensor as indicated on this thread. Indeed it was out of place and slightly bent. He was able to realign it and headlight sensor warning light went away. No problems so far. Knock wood. As for the bars, I still have the hollow core front bar as I can't afford the solid core. Therefore, I feel the front is about the same as stock but the rear def handles much better. While on the rack, my mechanic also noticed that my passenger rear spring has moved out of place and is possibly hitting the rear stabilizer link causing a "clank." Another repair for another day, I guess (maybe when I decide to change to coilovers).
Old 09-09-14, 09:15 AM
  #127
loveslexus
The Dog Whisperer
loveslexus's Avatar
Are there any "upgraded" front links? I'm thinking with stiffer bushings? Being that my car is an 02 I'd like to replace all the old rubber I can.
Old 09-12-14, 10:03 AM
  #128
loveslexus
The Dog Whisperer
loveslexus's Avatar
Is the ISX50 rear sway the same on the ISF? Looks like different part numbers.
Old 09-12-14, 10:35 AM
  #129
bacardi11
bacardi11's Avatar
the bar you want is the 2008 ISF rear sway bar.
Old 09-12-14, 01:04 PM
  #130
DarthSid
DarthSid's Avatar
You require the 2008 ISF rear sway bar which comes with the bend (arch) in the center. Here is a picture of the OEM rear sway bar in black, and the upgrade (17mm) painted red.
Old 12-09-14, 10:02 AM
  #131
416tt
416tt's Avatar
I guess I will be doing this mod , lucky for me that JDM shop is very close by and I wouldn't have to have a heavy item shipped, but they dont have the front in stock atm .. Ill start with rear..
was there a very noticeable difference in the rear end? and my car is lowered probably a little more then 1".. I guess ill order same links as DarthSid
Thanks guys
Old 12-09-14, 11:03 AM
  #132
bacardi11
bacardi11's Avatar
you'll be happy
Old 12-09-14, 04:07 PM
  #133
DarthSid
DarthSid's Avatar
Thanks guys
That's perfect. My car is also lowered a bit over one inch in the rear. The thread I posted with the links will fit perfectly with the ISF 17mm sway bar. Also order the urethane bushings from Fig Eng.
Old 12-12-14, 10:55 AM
  #134
DarthSid
DarthSid's Avatar
For club members interested in upgrading the rear sway bar please take notice Sewell has recently updated their website for part number 48812-30400 which can now be located under SC430 vs ISF 2008. The part price has also increased from $93 to $136.04 for Sewell members.
File Type: pdf
Old 12-12-14, 11:12 AM
  #135
416tt
416tt's Avatar
Thank you Bacardi and Darthsid!
Quick Reply: Sway Bar
