Sway Bar
Old 05-08-14, 07:01 PM
bcsc400
bcsc400's Avatar
With the CL discount from Sewell it's $94.39
Old 05-09-14, 05:08 AM
bacardi11
bacardi11's Avatar
this is one of the best upgrade for the 430sc
Old 05-09-14, 08:19 AM
ShawnOk
ShawnOk's Avatar
Great info! Thanks bacardi! If anyone chooses to take this mod on as a DIY, please post photos on how to do the change. Would really appreciate it!
Old 05-11-14, 12:46 PM
bacardi11
bacardi11's Avatar
One of guys from Japan said he had a rear 19mm on his car, said nice for the track changed back to the 17mm for the street. he is also using gs 28.6 front sway bar. I guess I get it right for the street. well balanced.
Old 05-15-14, 12:27 AM
Rollaboy
Rollaboy's Avatar
Very nice. Thanks for the info bacardi11 :-) The mod is on my list ;-)
Old 05-15-14, 07:48 AM
bcsc400
bcsc400's Avatar
Did you replace the brackets that hold the ISF bushings or did the stock ones work ok?
Old 05-15-14, 08:54 AM
bacardi11
bacardi11's Avatar
bcsc400
you must replace the bushing with the bar if bought new. I used the 430sc brackets
ebay for the JDM Lexus gs300 gs400 gs430 28.6mm front sway bar
Old 05-21-14, 11:01 PM
bclex430
bclex430's Avatar
What year of GS front you use ? Thank you !
Old 05-22-14, 02:19 AM
bacardi11
bacardi11's Avatar
ebay JDM lexus gs 300 GS 400 GS 430 front 28.6 perfect fit well balanced with the 2008 Stock ISF rear 17mm bar.
make sure you put the sway bar in correctly or you have a problem with your vsc/abs light in the dash.
Old 05-22-14, 05:22 AM
robertrios
robertrios's Avatar
So here is my question, if the stock ISF rear fits...then wouldnt the Fsport 2IS bar fit? We put on the 2IS fsport rear in the ISF world. So I would have to think they are both a match.
Old 05-22-14, 10:11 AM
bacardi11
bacardi11's Avatar
that would make since to me. one of the guys in Japan had the 19mm on his he though it was to much changed back to the 17mm
Old 05-22-14, 11:16 AM
bclex430
bclex430's Avatar
Thank you ! Bacardi11
Old 05-22-14, 11:21 AM
bcsc400
bcsc400's Avatar
I think the F sport bar is a different shape (straight) and won't fit the SC430.
Old 05-22-14, 12:15 PM
bacardi11
bacardi11's Avatar
yes I think your right its a straight bar. to go from stock 12mm to 17mm is a big difference. when you put the stock 12mm next to the 17mm you see it.
Old 05-22-14, 03:04 PM
bacardi11
bacardi11's Avatar
like I said JDM gs 28.6mm and the ISF 17mm this is the ISF setup from the factory. I like how the car handles now.
Quick Reply: Sway Bar
