Sway Bar
Old 02-04-15, 08:46 AM
  #136
bb430
bb430's Avatar
First of all, I want to thank bacardi11,DarthSid and others that have contributed to make this upgrade easy to understand and possible.
I have purchased the rear bar set from Sewell and from Canada the front bar along with new front bushings from other source. However, the front bar I've gotten from Canada (Moe) was NOT a solid bar, it was a hollow bar. I am very disappointed with this order and had just email Moe regarding this matter. Hopefully we can have a satisfactory result.
The installation was really simple and straightforward. I can feel the difference from my short test drive already. The rear does have the biggest feel to me specially over a small bump and quick lane change. The front didn't give me any better impression of improvement, maybe because of the hollow bar I've gotten, or maybe it's just me. But none the less I do recommend this upgrade to all our members. Once again, big thanks to all the contributors.
Old 02-04-15, 09:06 AM
  #137
LexBrett
LexBrett's Avatar
My front gs400 sway bar didn't seem to give me any improved gangling either? How do you know if it is hollow or not?
Old 02-04-15, 09:08 AM
  #138
bacardi11
bacardi11's Avatar
bb430
thanks my front bar was solid darthsid bar also Hollow even from Swells the bar is Hollow I don't no why.
what the 28.6 front sway bar dose is balance the setup. the ISF stock setup is 28.6mm front and 17mm rear.
Old 02-04-15, 09:10 AM
  #139
bb430
bb430's Avatar
From the end of the bar, yon can see the folding together to make a flat end. AND it weights a whole lot less then the smaller OEM bar.
Old 02-04-15, 09:16 AM
  #140
bb430
bb430's Avatar
I don't think the hollow bar makes any improvement but only the weight savings. When I was racing Porches in the old days, I did buy size bigger roll bars but hollowed (4mm thicker) to save weight but not performance.
Old 02-04-15, 09:21 AM
  #141
LexBrett
LexBrett's Avatar
Is there a front sway bar that is not hollow? I think Greg runs a TRD?
Old 02-04-15, 09:34 AM
  #142
bacardi11
bacardi11's Avatar
lex
greg front bar is 32mm solid
Old 02-04-15, 09:44 AM
  #143
bb430
bb430's Avatar
Well, according to bacardi11 the bar he bought was a solid bar. Given the known fact, I would have just upgraded the rear and kept the front unchanged. Maybe just upgrade the front bushings to poly that's al. I still think the improvement overall was there but just not as expected much.
FYI, Moe replied and said that he sold me just as advertised, I guess it was me that did not ask and just assumed. If this were ordered in States I would have returned it. But Canada? I'll just have to eaten it.
Old 02-04-15, 09:59 AM
  #144
ShawnOk
ShawnOk's Avatar
Same exact thing happened to me. With Moe also. I think he specifically advertises in that way. I did the exact same thing you did; ordered it, found out after that a solid bar was possible, asked for return, too expensive to ship. Stuck with it now. Adding the Cusco STB def helped improve front suspension to the hallow bar. Rear was def the huge game changer overall though.
Old 03-18-15, 12:06 PM
  #145
416tt
416tt's Avatar
Guys,
since Sewellparts is no longer available.. where can I get this ISF bar? I was going to order from dealer here except they said it will take long as none are available..
anyone selling a used?
Thanks
Old 03-18-15, 01:26 PM
  #146
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
Since some you are using the GS400 sways bar.. Here's another alternative that you will definitely feel since these are larger in diameter..
http://www.ebay.com/itm/Front-Sway-Bar-Stabilizer-Anti-Roll-Arm-fit-Lexus-98-00-GS400-98-05-GS300-/321688626225?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AGS400&hash=item4ae622e431&vxp=mtr
Old 03-18-15, 01:40 PM
  #147
bacardi11
bacardi11's Avatar
tmf2004
the rear bar would not work you have to mod. the center post.
Old 03-18-15, 03:10 PM
  #148
Harold57
Harold57's Avatar
Originally Posted by bimmer416
Guys,
Thanks
Bimmer, Sewell is still in business, you just have to call them now.
Old 03-25-15, 07:26 PM
  #149
lead366
lead366's Avatar
Hi Guys;
I have a 2002 sc and hated the ride so the first thing I did was get rid of the run flat tires...WOW!
Interesting thread indeed. Im in Hawaii and have noticed a squeak or creek when I go over bumps at low speeds. My mechanic here says it is sway bar bushing and quoted me 195 bucks. Seems high for one bushing...rip off?
Also...Im now interested in replacing both sway bars...from what you all say?...sounds like a big difference. Could you all please comment as to what difference I will feel in handling? I can't really "punch it" down here but I do appreciated smooth rides.
Also----to confirm...what parts do I order and where?
Thanks to all
Old 03-25-15, 07:57 PM
  #150
bb430
bb430's Avatar
If it were making squeaky and creaky sound and assuming it come from the bushings, you can check them and lube them with urethane grease first to see if they were in fact the noise maker before you spend bigger bucks.
They are pretty easy to get to and lube them.
Quick Reply: Sway Bar
