Lowering
Old 04-22-14, 12:51 PM
WIL44
WIL44's Avatar
Originally Posted by texsexlex
...appreciate the info...I'm going to get with another member here with air & take a test ride.i may pm you a little later on,when I get closer to doing it...thanx again
No problem. I will help as much as I can. Plenty of photos.
Cheers
Steve
Old 04-30-14, 07:46 PM
gr8t808
gr8t808's Avatar
I was in the same predicament; purchased spacers 25mm front and 38mm back with ISF wheels. I recently changed rims and dropped 1.2" all around using Sage RCA kits. And it was less than $500, DYI.
Attached Thumbnails Lowering-img_0089.jpg   Lowering-img_0080.jpg   Lowering-img_0081.jpg   Lowering-img_0087.jpg
Old 04-30-14, 11:58 PM
PHML
Master Thread Closer!!
PHML's Avatar
Walt, lookin good...and you still retain you Lexus ride quality too.
Pete
Old 05-24-14, 01:25 PM
robertrios
robertrios's Avatar
hey guys Ive been on TTE springs since 2010 and I think I want to lower the front end just a little bit more, which spring gives the most drop? Any draw backs to keeping the TTE's in the back but swapping out the fronts?
Old 10-22-14, 10:59 AM
PHML
PHML's Avatar
I would recommend keeping the TTE springs all around...and getting a smallest RCA kit for the front if you want it dropped it bit. The great thing about the RCA kit is that its an easy mod. Just remove 2 bolts on each side...lift the hub/brake assembly...place the RCA block onto the lower ball joint...then place the hub/brake assembly back down...and secure in place with the new longer bolts. Good luck.
Pete
ddvette9
Suspension and Brakes
02-15-15 09:49 PM
ThermonMer
03-24-11 12:27 PM
anson89
IS F (2008-2014)
09-22-10 03:17 PM
Kybball#1
28
05-24-10 09:08 AM
gs350on22s
Suspension
03-05-09 12:39 PM
Quick Reply: Lowering
