Right side front brake works better then left side ?
Old 02-20-14, 08:20 AM
416tt
416tt's Avatar
Default Right side front brake works better then left side ?
Hello,
my front right brake seems to work better then my left.. do you guys know what it could be? my car pulls to the right when I press brake.. im going to be replacing my brakes this summer but before I do that I wana know whats causing this so my new brakes dont get ruined.. any ideas?
Thanks
Old 02-20-14, 09:21 AM
kjcole
kjcole's Avatar
First, check front-end alignment and tire conditions. If those check out, then, unless there are contaminants on the rotors of the offending side, it is time to jump in there and do a standard brake job. Replace pads, rotors, make sure caliper pistons aren't sticking (clean up the piston surfaces), and purge/replace the brake fluid. Do it right, and you will be back to specs.
Old 02-20-14, 12:54 PM
bb430
bb430's Avatar
Most likely you need an alignment, hopefully is not your right side bearing or your A arm going out.
Old 02-21-14, 03:19 AM
PATLESS
PATLESS's Avatar
Guys, he said it pulls when he steps on the brakes. One of the ca[ipers is not working correctly. Could be a number of things, but most likely one caliber is hanging up. Other options are crimped brake line.. If allignment it most likely would pull all the time
Old 02-24-14, 07:17 AM
416tt
416tt's Avatar
thankyou for your replies everyone, I assume this is not something I can do myself.. to be honest i already had my bearings and my hubs changed.. but didnt get an allignment because winter started.. so now im just waiting for it to get warm so I can install coilovers and then get a perfect allignment...
I do know that my rotors have some grooves but the car definately does brake better on the right side.. should i take it to a mechanic to check? and would the steel or metal brake lines be a good upgrade?
thankyou
GSMidnight
08-07-10 11:01 PM
cbaker
Suspension and Brakes
02-26-07 09:28 AM
400 Degrez
01-26-07 05:40 AM
JCW
03-16-06 10:01 AM
Wald GS
GS - 1st Gen (1993-1997)
05-28-03 01:38 AM
Quick Reply: Right side front brake works better then left side ?
