new OBD2 scanner
Old 11-03-13, 05:52 PM
ebear695
ebear695's Avatar
Default new OBD2 scanner
finally took delivery of a new OBD2 scanner and used it on my 2002 SC. I received codes of
P0440, 0441 AND 0446, ALL evap emmision. The dealer had cleared some codes, did not tell me what they were, up they tightened the fuel cap, and I have been doing this at every fill up. But the code came back. No drivalilty problems, just the CIL.
I just cleared the codes and tightened the cap once again, next chance I will check the vac lines to the canister, it I can find them. any other DIY fixes I might check and do?
BTW where is the canister on the SC?
Old 11-18-13, 09:11 AM
kjcole
kjcole's Avatar
Check the lines at the driver's side engine right under the engine shroud. Those tend to come unhooked if the motor mounts are weak. Also I've had a plastic nipple break off on those lines, throwing the same codes.
bob2200
RX - 1st Gen (1999-2003)
12-08-13 01:33 PM
dell2011
04-20-11 05:12 AM
Mega
09-14-10 09:08 AM
02Ku
12-24-07 03:23 AM
Quick Reply: new OBD2 scanner
