Resurface rotors?
Old 09-25-13, 05:29 AM
misskris
misskris's Avatar
Question Resurface rotors?
Hi!
I took my car to the "stealership" (Westside Lexus) yesterday after I heard a loud grinding/rubbing noise only when I would turn my car sharp to the right.
They said I need new bearings, which sounds right. That is covered under my extended warranty.
They also said that I need to resurface my rotors and that would be a customer pay of $195.00. That doesn't sound right to me. I haven't noticed any shaking in my steering wheel and the only problem I have been experiencing is the rubbing/grinding noise in the last few days.
I replaced the rotors myself last December and they were brand new from Sewell parts. I paid $191.32 for the parts on Sewell.
My question is:
Do I need these rotors resurfaced after only 9 months? Are they messing with me? Should I just buy a new set of rotors for $191.32 from Sewell?
Any advice is greatly appreciated.
Old 09-25-13, 06:33 AM
416tt
416tt's Avatar
The rubbing and grinding noise are not your rotors they should be your bearings/pads sticking. Im having a similar issue where my pads & rotors installed last summer are ruined. Do you hear any sound when braking? and you said no shaking or vibration when braking right? if yes thats exactly the problem im having. Pads sticking seems to be a common issue apparently..
What did make it better is the triangle pin which pushes the pads apart, I pulled it apart more before puting it in from on side to other so it pushes the pads apart easily when brake isnt pressed.
I would not give 195$ to refinish rotors, I would definately buy new for that price, but your pads and calipers need checking. I suggest you open it up yourself and check if the clips in the caliper the pads sit into are letting the pad slide easily, clean & put some grease on them and also re stretch that pins which goes from one pad to the other, if corrected, your pads should be pushing apart very well and easily. This will make it better but if your pads were sticking, there surface will not be even and not visible to the bare eye.
I need both new rotors and pads :/ but before that i think im going to get my brake fluid flushed, im also going to buy new caliper hardware kit (around $20) which contains all the clips/pins, etc...
Old 09-25-13, 07:30 AM
kjcole
kjcole's Avatar
Wheel bearings usually click or growl when bad even when driving straight ahead but I suppose that turn specific growling can occur if that front hub is going bad. Usually when they are bad they just howl all the time, or grinding can happen. If the rotors and pads looked good, then the bad wheel bearing makes sense. However, the bad rotors suggest stuck calipers or pad hardware, which may be unrelated to the hub, unless that hub is so floppy that the rotor is going out of alignment with the caliper (! but your steering would be erratic and the tire would start wearing oddly). Or, the hub/bearing is fine. Since they said that the wheel bearing/hub was bad, I can believe that, but I'm a PITA so I'd ask them how they got to a diagnosis of the wheel bearing/hub (one or both sides???), and then why new rotors need resurfacing.
Old 09-25-13, 12:39 PM
thombiz
thombiz's Avatar
Having a wheel bearing fail is almost unheard of. As for me, I think the problem is with your brake calipers. Brake fluid absorbs water out of the air. This is the reason to flush the brake fluid...to get rid of the water saturated brake fluid and replace with new. Water is heavier than the specific gravity of the brake fluid so it settles to the lowest point which is your calipers. This water comes into contact with the iron of the brake calipers causing them to rust and pit. The brake piston which travels inside the caliper catches on the rust and pits and hangs up the piston causing the brake pads to not fully unseat from the rotors. This causes the rotors to get hot, scratch, and develop rough patches. Check your rotors carefully for these conditions. If they exist, it is almost certainly faulty calipers causing the brake pads to rub against the rotors. Flush the brake fluid, replace faulty calipers, and put on new rotors and you'll be good to go. Almost nobody ever resurfaces rotors any more, they just replace them.
Checking front bearings is easy. Jack up the wheel like you would to change a tire, and spin the wheel by hand listening carefully to the bearings. If the bearing is faulty, it will make a grinding/screeching noise. If the wheel does not spin easily, then check brakes.
Old 09-26-13, 03:19 AM
iolmaster
iolmaster's Avatar
Checking front bearings is easy. Jack up the wheel like you would to change a tire, and spin the wheel by hand listening carefully to the bearins. If the bearing is faulty, it will make a grinding/screeching noise. If the wheel does not spin easily, then check brakes.
"Nobody ever resurfaces rotors anymore." Huh? It is done all the time. I do it all the time. I have no idea why you would say that. There is nothing wrong with resurfacing a rotor.
Old 09-26-13, 06:54 AM
thombiz
thombiz's Avatar
I agree that there is nothing wrong with resurfacing rotors, and I used to have it done all the time. My experience is that most rotors don't have enough thickness to be resurfaced. By the time they are resurfaced, they are right at the minimum acceptable thickness stamped on the rotor. Luckily, the price of new quality aftermarket rotors is acceptable. I get mine here: http://www.raceshopper.com/
Old 09-26-13, 06:55 AM
RCsGX
RCsGX's Avatar
You left out the key word before nobody, which was almost.
There's nothing wrong with resurfacing your rotors but if you can buy new OEM rotors and replace them yourself why would you ever want to have them resurfaced? Case in point below. I guess if you don't have the time to replace them or if you don't know how to replace them then resurfacing is a cheaper option than having the dealer replace the rotors......
Originally Posted by misskris
Hi!
Old 09-26-13, 06:57 AM
Joeb427
Joeb427's Avatar
In the past rotors were thick and heavy but not today for less weight..
Some resurfaced rotors today will warp.
Old 09-26-13, 09:21 AM
misskris
misskris's Avatar
Thanks guys. I appreciate your input.
Actually, a bearing fail is a pretty common problem. Try googling it and you will see all of the issues people have had.
I diagnosed the front wheel bearing & hub assembly replacement before I even took it to the dealership. They just confirmed my diagnosis.
My question above was in regards to resurfacing the rotors and whether I should even bother since :
(1) they are only 9 months old. I purchased them OEM new from Sewell for $191.32, and
(2) I didn't notice any shaking in my steering wheel or any reason I would have a problem with the rotors.
My point is I think they were looking to make an additional $195 on me.
If there is a problem with the rotors, I will just buy new ones since I can purchase them cheaper than resurfacing the ones I have that are only 9 months old.
Everything else has been checked on the car and there are no issues with pads, calipers, fluids, etc.
Thanks y'all!
Old 09-26-13, 09:33 AM
misskris
misskris's Avatar
FYI... I just looked on Sewell and the OEM front rotor set is even less expensive when I purchased them last year. They are now $135.08 for the front set.
Old 09-27-13, 04:00 PM
jzwu
jzwu's Avatar
Thanks y'all!
Your rotors are fine. No need to do anything. Just decline the dealer's offer.
Old 09-27-13, 11:24 PM
StillLine
StillLine's Avatar
Default No money out of pocket!
misskris,
You had it right about 8 words into your original post. "Stealership" is spot on! Let them do the warranty wheel bearing repair, kindly refuse the offer to unnecessarily resurface the rotors and go elsewhere in the future, if that's possible. Sucks to be the potential victim of this kind of tactic. This dealership is obviously trying to take advantage of you.
Best wishes,
StillLine
Old 09-28-13, 03:09 PM
PATLESS
PATLESS's Avatar
Default Do rotors really warp
Like the rest of you guys, I always assumed rotors warped, a mechanic friend sent me this.
StopTech Logo
HOME
ABOUT US
DEALER LOGIN
http://www.stoptech.com/technical-su...nd-other-myths
The "Warped" Brake Disc and Other Myths of the Braking System
by Carroll Smith
Myth # 1 – BRAKE JUDDER AND VIBRATION IS CAUSED BY DISCS THAT HAVE BEEN WARPED FROM EXESSIVE HEAT.
The term "warped brake disc" has been in common use in motor racing for decades. When a driver reports a vibration under hard braking, inexperienced crews, after checking for (and not finding) cracks often attribute the vibration to "warped discs". They then measure the disc thickness in various places, find significant variation and the diagnosis is cast in stone.
When disc brakes for high performance cars arrived on the scene we began to hear of "warped brake discs" on road going cars, with the same analyses and diagnoses. Typically, the discs are resurfaced to cure the problem and, equally typically, after a relatively short time the roughness or vibration comes back. Brake roughness has caused a significant number of cars to be bought back by their manufacturers under the "lemon laws". This has been going on for decades now - and, like most things that we have cast in stone, the diagnoses are wrong.
With one qualifier, presuming that the hub and wheel flange are flat and in good condition and that the wheel bolts or hat mounting hardware is in good condition, installed correctly and tightened uniformly and in the correct order to the recommended torque specification, in more than 40 years of professional racing, including the Shelby/Ford GT 40s – one of the most intense brake development program in history - I have never seen a warped brake disc. I have seen lots of cracked discs, (FIGURE 1) discs that had turned into shallow cones at operating temperature because they were mounted rigidly to their attachment bells or top hats, (FIGURE 2) a few where the friction surface had collapsed in the area between straight radial interior vanes, (FIGURE 3) and an untold number of discs with pad material unevenly deposited on the friction surfaces - sometimes visible and more often not. (FIGURE 4)
In fact every case of "warped brake disc" that I have investigated, whether on a racing car or a street car, has turned out to be friction pad material transferred unevenly to the surface of the disc. This uneven deposition results in thickness variation (TV) or run-out due to hot spotting that occurred at elevated temperatures.
In order to understand what is happening here, we will briefly investigate the nature of the stopping power of the disc brake system.
THE NATURE OF BRAKING FRICTION
Friction is the mechanism that converts dynamic energy into heat. Just as there are two sorts of friction between the tire and the road surface (mechanical gripping of road surface irregularities by the elastic tire compound and transient molecular adhesion between the rubber and the road in which rubber is transferred to the road surface), so there are two very different sorts of braking friction - abrasive friction and adherent friction. Abrasive friction involves the breaking of the crystalline bonds of both the pad material and the cast iron of the disc. The breaking of these bonds generates the heat of friction. In abrasive friction, the bonds between crystals of the pad material (and, to a lesser extent, the disc material) are permanently broken. The harder material wears the softer away (hopefully the disc wears the pad). Pads that function primarily by abrasion have a high wear rate and tend to fade at high temperatures. When these pads reach their effective temperature limit, they will transfer pad material onto the disc face in a random and uneven pattern. It is this "pick up" on the disc face that both causes the thickness variation measured by the technicians and the roughness or vibration under the brakes reported by the drivers.
With adherent friction, some of the pad material diffuses across the interface between the pad and the disc and forms a very thin, uniform layer of pad material on the surface of the disc. As the friction surfaces of both disc and pad then comprise basically the same material, material can now cross the interface in both directions and the bonds break and reform. In fact, with adherent friction between pad and disc, the bonds between pad material and the deposits on the disc are transient in nature - they are continually being broken and some of them are continually reforming.
There is no such thing as pure abrasive or pure adherent friction in braking. With many contemporary pad formulas, the pad material must be abrasive enough to keep the disc surface smooth and clean. As the material can cross the interface, the layer on the disc is constantly renewed and kept uniform - again until the temperature limit of the pad has been exceeded or if the pad and the disc have not been bedded-in completely or properly. In the latter case, if a uniform layer of pad material transferred onto the disc face has not been established during bedding or break-in, spot or uncontrolled transfer of the material can occur when operating at high temperatures. The organic and semi-metallic pads of the past were more abrasive than adherent and were severely temperature limited. All of the current generation of "metallic carbon", racing pads utilize mainly adherent technology as do many of the high end street car pads and they are temperature stable over a much higher range. Unfortunately, there is no free lunch and the ultra high temperature racing pads are ineffective at the low temperatures typically experienced in street use.
Therefore - there is no such thing as an ideal "all around" brake pad. The friction material that is quiet and functions well at relatively low temperatures around town will not stop the car that is driven hard. If you attempt to drive many cars hard with the OEM pads, you will experience pad fade, friction material transfer and fluid boiling - end of discussion. The true racing pad, used under normal conditions will be noisy and will not work well at low temperatures around town.
Ideally, in order to avoid either putting up with squealing brakes that will not stop the car well around town or with pad fade on the track or coming down the mountain at speed, we should change pads before indulging in vigorous automotive exercise. No one does. The question remains, what pads should be used in high performance street cars - relatively low temperature street pads or high temperature race pads? Strangely enough, in my opinion, the answer is a high performance street pad with good low temperature characteristics. The reason is simple: If we are driving really hard and begin to run into trouble, either with pad fade or boiling fluid (or both), the condition(s) comes on gradually enough to allow us to simply modify our driving style to compensate. On the other hand, should an emergency occur when the brakes are
cold, the high temperature pad is simply not going to stop the car. As an example, during the mid 1960s, those of us at Shelby American did not drive GT 350 or GT 500 Mustangs as company cars simply because they were equipped with Raybestos M-19 racing pads and none of our wives could push on the brake pedal hard enough to stop the car in normal driving.
Regardless of pad composition, if both disc and pad are not properly broken in, material transfer between the two materials can take place in a random fashion - resulting is uneven deposits and vibration under braking. Similarly, even if the brakes are properly broken, if, when they are very hot or following a single long stop from high speed, the brakes are kept applied after the vehicle comes to a complete stop it is possible to leave a telltale deposit behind that looks like the outline of a pad. This kind of deposit is called pad imprinting and looks like the pad was inked for printing like a stamp and then set on the disc face. It is possible to see the perfect outline of the pad on the disc. (FIGURE 5)
It gets worse. Cast iron is an alloy of iron and silicon in solution interspersed with particles of carbon. At elevated temperatures, inclusions of carbides begin to form in the matrix. In the case of the brake disk, any uneven deposits - standing proud of the disc surface - become hotter than the surrounding metal. Every time that the leading edge of one of the deposits rotates into contact with the pad, the local temperature increases. When this local temperature reaches around 1200 or 1300 degrees F. the cast iron under the deposit begins to transform into cementite (an iron carbide in which three atoms of iron combine with one atom of carbon). Cementite is very hard, very abrasive and is a poor heat sink. If severe use continues the system will enter a self-defeating spiral - the amount and depth of the cementite increases with increasing temperature and so does the brake roughness. Drat!
PREVENTION
There is only one way to prevent this sort of thing - following proper break in procedures for both pad and disc and use the correct pad for your driving style and conditions. All high performance after market discs and pads should come with both installation and break in instructions. The procedures are very similar between manufacturers. With respect to the pads, the bonding resins must be burned off relatively slowly to avoid both fade and uneven deposits. The procedure is several stops of increasing severity with a brief cooling period between them. After the last stop, the system should be allowed to cool to ambient temperature. Typically, a series of ten increasingly hard stops from 60mph to 5 mph with normal acceleration in between should get the job done for a high performance street pad. During pad or disc break-in, do not come to a complete stop, so plan where and when you do this procedure with care and concern for yourself and the safety of others. If you come to a complete stop before the break-in process is completed there is the chance for non-uniform pad material transfer or pad imprinting to take place and the results will be what the whole process is trying to avoid. Game over.
In terms of stop severity, an ABS active stop would typically be around 0.9 G’s and above, depending on the vehicle. What you want to do is stop at a rate around 0.7
to 0.9 G's. That is a deceleration rate near but below lock up or ABS intervention. You should begin to smell pads at the 5th to 7th stop and the smell should diminish before the last stop. A powdery gray area will become visible on the edge of the pad (actually the edge of the friction material in contact with the disc - not the backing plate) where the paint and resins of the pad are burning off. When the gray area on the edges of the pads are about 1/8" deep, the pad is bedded.
For a race pad, typically four 80mph to 5 and two 100mph to 5, depending on the pad, will also be necessary to raise the system temperatures during break-in to the range that the pad material was designed to operate at. Hence, the higher temperature material can establish its layer completely and uniformly on the disc surface.
Fortunately the procedure is also good for the discs and will relieve any residual thermal stresses left over from the casting process (all discs should be thermally stress relieved as one of the last manufacturing processes) and will transfer the smooth layer of pad material onto the disc. If possible, new discs should be bedded with used pads of the same compound that will be used going forward. Again, heat should be put into the system gradually - increasingly hard stops with cool off time in between. Part of the idea is to avoid prolonged contact between pad and disc. With abrasive pads (which should not be used on high performance cars) the disc can be considered bedded when the friction surfaces have attained an even blue color. With the carbon metallic type pads, bedding is complete when the friction surfaces of the disc are a consistent gray or black. In any case, the discoloration of a completely broken in disc will be complete and uniform.
Depending upon the friction compound, easy use of the brakes for an extended period may lead to the removal of the transfer layer on the discs by the abrasive action of the pads. When we are going to exercise a car that has seen easy brake use for a while, a partial re-bedding process will prevent uneven pick up.
The driver can feel a 0.0004" deposit or TV on the disc. 0.001" is annoying. More than that becomes a real pain. When deposit are present, by having isolated regions that are proud of the surface and running much hotter than their neighbors, cementite inevitably forms and the local wear characteristics change which results in ever increasing TV and roughness.
Other than proper break in, as mentioned above, never leave your foot on the brake pedal after you have used the brakes hard. This is not usually a problem on public roads simply because, under normal conditions, the brakes have time to cool before you bring the car to a stop (unless, like me, you live at the bottom of a long steep hill). In any kind of racing, including autocross and "driving days" it is crucial. Regardless of friction material, clamping the pads to a hot stationary disc will result in material transfer and discernible "brake roughness". What is worse, the pad will leave the telltale imprint or outline on the disc and your sin will be visible to all and sundry.
The obvious question now is "is there a "cure" for discs with uneven friction material deposits?" The answer is a conditional yes. If the vibration has just started, the chances are that the temperature has never reached the point where cementite begins to form. In this case, simply fitting a set of good "semi-metallic" pads and using them hard (after bedding) may well remove the deposits and restore the system to normal operation but with upgraded pads. If only a small amount of material has been transferred i.e. if the vibration is just starting, vigorous scrubbing with garnet paper may remove the deposit. As many deposits are not visible, scrub the entire friction surfaces thoroughly. Do not use regular sand paper or emery cloth as the aluminum oxide abrasive material will permeate the cast iron surface and make the condition worse. Do not bead blast or sand blast the discs for the same reason.
The only fix for extensive uneven deposits involves dismounting the discs and having them Blanchard ground - not expensive, but inconvenient at best. A newly ground disc will require the same sort of bedding in process as a new disc. The trouble with this procedure is that if the grinding does not remove all of the cementite inclusions, as the disc wears the hard cementite will stand proud of the relatively soft disc and the thermal spiral starts over again. Unfortunately, the cementite is invisible to the naked eye.
Taking time to properly bed your braking system pays big dividends but, as with most sins, a repeat of the behavior that caused the trouble will bring it right back.
Old 09-30-13, 10:25 AM
misskris
misskris's Avatar
Thanks to all of you! Just as I thought!
Old 09-30-13, 06:27 PM
SC43052
SC43052's Avatar
I agree that the dealer is trying to do a little double-dipping by getting warranty work from Lexus and additional money from you.
The wheel bearings are a lot more involved than just changing rotors. You have replaced rotors yourself and can easily do it again if required (whether you pull the rotors off and have them turned or replace them with new).
But make that decision AFTER the wheel bearings are done. If after the bearings are replaced it drives great with no noise or pulling at braking then you have kept the money in your pocket instead of the $tealers!
Quick Reply: Resurface rotors?
