My new LED DRL's installed
Old 07-05-13, 09:57 PM
  #61
mandyfig
mandyfig's Avatar
I finally wrapped up the wiring, straight forward as StillLine mentioned. The remote works great. There is a ON and an OFF, so you can make sure it is off when you do not need it. I have 2 keys and there's 2 remotes.
Old 07-06-13, 04:26 AM
  #62
mandyfig
mandyfig's Avatar
Here are some daylight pics, cloudy day though.
Old 07-06-13, 04:53 AM
  #63
bacardi11
bacardi11's Avatar
mandy
they don't look like they belong there just my 02 cents.
Old 07-06-13, 05:57 AM
  #64
mandyfig
mandyfig's Avatar
Would have been better if they were lower in the grille but there was no space.
I will keep it on for a while. They are just taped in there (it is not going any place).
My fear is if I forget to turn it off, there goes the battery.
Old 07-06-13, 09:38 AM
  #65
MrMark
MrMark's Avatar
In NJ, this is asking to get pulled over.....
Old 07-06-13, 10:50 AM
  #66
mandyfig
mandyfig's Avatar
That's why I have a remote. Whenever I see some...I turn it off. Not really that bright. It is the same as my existing LED DRL in intensity.
Old 07-07-13, 01:51 PM
  #67
1NEAT_SC
1NEAT_SC's Avatar
Beautiful car. I think they look ok.... still wondering about the yellow when the lights are off..??
Mandy, did you look into wiring them so they come on with the ignition and you could also put the remote in series and turn them off when you wanted too. I'm a little afraid I would leave them on too. Maybe they could be wired into the headlights so they stay on until they time out as normal?
Thanks for the pictures,
lar
Old 07-08-13, 05:42 AM
  #68
mandyfig
mandyfig's Avatar
Wiring it hot all the time was to be able to turn them on “on demand,” like when approaching a car at night. But you are right there will be a time when you will forget to turn them off as I did once this weekend, was at the auto parts store and I realized I left them on.
I have been thinking about this.
It will be easy to switch it over to a fuse that is ignition on hot by moving the tap to an IGN on fuse.
Old 07-08-13, 05:48 AM
  #69
mandyfig
mandyfig's Avatar
lar
Thanks lar.
Do not know why yellow, I bet you it is because it gave them the best end result illumination. Also hides the LED’s. When I sprayed the LED surface with translucent brown tint, the LED array was visible. The colored tinting was to hide the array obviously but why yellow, there must have been a reason behind it. If you understand paint and tinting, you will appreciate “hideability.” I am no paint expert, just have a little knowledge on paint since we do painting of plastics in my job.
Old 07-08-13, 11:30 AM
  #70
zibby07
zibby07's Avatar
Originally Posted by mandyfig
Thanks lar.
Any pictures of the wiring ?
Thanks!
Old 07-08-13, 11:42 AM
  #71
mandyfig
mandyfig's Avatar
Fairly simple, for the PLUS (+) connect to the # 9 location on the fuse box as earlier shown. For the minus, go directly to the Minus (-) of the battery. I will post a pic later. For the LEDs, tie the blacks and reds. Red would be PLUS Positive and Black would be Minus, Ground.
If using a remote relay, just follow the wiring instructions which are self explanatory.
Then play around the On and Off button on the remote, QED.
Old 07-09-13, 02:01 PM
  #72
mandyfig
mandyfig's Avatar
Continuing the saga...I need some tint...off to wallyworld.
Old 07-09-13, 03:59 PM
  #73
Autoplak
Autoplak's Avatar
Great look mandyfig,
Congratulations.
So for dumb electrical guys like me.
You;
1. place the DRLs per your liking
2. route the driver's side wire behind the grill and in front of the radiator
3. splice the 2 wires together
4. route a single wire to the fuse box in front of the battery.
5. split the wire
6. wedge a single wire into the #9 TEL 5 Amp fuse or switch out to a Mini Fused Circuit
7. loosen the negative battery connection and wedge the other wire and tighten.
8. force the fuse cover on the box and over the wire
Is this correct?
Question, this #9 fuse is only live with the ignition? I'm admittedly slow and don't want to have to keep remembering to turn off the lights and carry around another remote.
Old 07-09-13, 05:13 PM
  #74
pvong713
pvong713's Avatar
If u mean tint paper then I agree! just cover the whole thing with black tint paper or a different color nobody will see it anyways!
Old 07-11-13, 04:58 PM
  #75
zibby07
zibby07's Avatar
Do you know which fuse is associated with the DRL's?
I wanted to set it up such that the LED's are only on when the DRL's are on.
Thanks.
Quick Reply: My new LED DRL's installed
