First post and new car...
Just so we get off on the right foot: You all stink of elderberries!
Anyway, allow me to show off the 2002 SC430 I just bought for the wife. 75000 miles.
I have the obligatory new trunk lifts on order from Ebay.
Body seems straight, though there are a couple of chips to tidy up.
If you all would be so kind, tell me about the much-ballyhooed 10 year waterpump/timing belt change. Can I wait until I get the usual water pump bearing failure/ water leaks before undertaking this? Or must it be tackled without delay? I understand the risk to the engine, but I wondered about the manner in which these fail in the SC430. Will I have some warning?
Anything else I should check straightaway?
Thanks, paxfish
Thanks, paxfish
Welcome Nice car . Did you get the service history. The manual recommends years and mileage. If you have low mileage then you are supposed to base it on years. That said I would think you need to do this sooner then later. Others will chime in on your question. Need to see if you need your fluids changed That would be in a service record assuming the former owner serviced it at lexus.
Buddy
Buddy
Paxfish welcome to CL. Very nice SC430. Classic Black. Awesome set of rims as well. As mentioned above, if you have not done it, register on Lexus.com (owner’s site), fairly simple input of VIN will tell you all you need to know what has been done to your car from a Lexus Dealer.
75,000 miles is quite young. The unknown is the quality of the 75,000 miles, driven hard or pampered highway miles. If you suspect it has had a hard life, a timing belt change plus water pump is in order. The peace of mind that comes with it is worth the investment. You have another 75K miles of serenity. And if it is going to be leisure car, it will take you forever to pile on miles.
Welcome again and post more pics when you can. BTW, are you a hands on DIYer?
Spacers, need spacers.
Thanks for the welcome. To answer a couple of questions:
It was babied, though not serviced at dealer. I have a line on the service records.
Tires/rims are stock sizes, and yeah, when those Kuhmos wear out, I'll go a bit wider I think.
The color is black with a bit of purple in it under sunlight. The wife is delighted
Taking a look at:
Dr. Colorchip for the 10 years worth of chips.
Axle-back exhaust for a little burble, (but not too much). considering this one, if anyone has any feedback: http://www.topspeedauto.com/index.ph...product_id=774
And yeah - I'm a DIY. The waterpump/timing belt doesn't look too bad, but we'll see.
Taking a look at:
Taking a look at:
Taking a look at:
Welcome. Nice car. I agree with the others. I did the belt change when I bought my '02 with 84K miles a couple of months ago. One thing you might check out as well is the belt tensioner. Apparently mine was hanging on just barely attached and is a common problem with a (relatively) cheap fix. New fluids are also a good idea if your records are not complete.
Whaddya think, Guys? Would adding a 1 inch spacer on the wheels seem about right?
(edit: nevermind, I did some more in-depth searching. It sounds like 25mm front and 35mm rear is a good combo for stock-sized wheels and rims. - Thanks!)
vietpr1nce
02-12-16 07:31 PM
