Console transmission shift bezel
Old 05-22-13, 05:14 AM
mrblister
mrblister's Avatar
Default Post pic for liners shift plate
Originally Posted by liners1
I have never posted a pic before and have never pasted before. I guess I will have to get my six year old grandson to help!
I am posting pic for liners of his problem.
Old 05-22-13, 09:11 AM
FLYCT
FLYCT's Avatar
Looking at the picture that part appears to be the "shift position indicator"
I'm not sure of the year of liners car but for the 5 speed 2002-2005 here s the information on replacement part.
If car is newer et me know and I'll research part number.
Sewell Lexus Parts listing page:link
http://lexus.sewellparts.com/oem-cat...C430-2003.html
Part number 3597824020
Price with CLUB LEXUS DISCOUNT if you register at Sewell with your Club Lexus user name = $138
JR
Old 05-22-13, 09:23 AM
FLYCT
FLYCT's Avatar
JR
I just looked up the part number for "INDICATOR, SHIFT POSITION" 2006-2010 and it's 3597824050. Price at Sewell with CL discount is $158.
JR
Old 05-22-13, 01:47 PM
mandyfig
mandyfig's Avatar
My Bezel is painted metallic gray.
Liners' is silver, I thought all of them were the same, metallic gray.
In my TL, the shifter bezel was painted but underneath was chromed. We removed the paint and had bright chrome bezels! All we did was use a paint remover. I wonder if this is applicable here.
Guess not because the substrate is showing as black plastic.
Old 05-22-13, 02:19 PM
FLYCT
FLYCT's Avatar
Here's the one from my 2007 SC430
JR
Old 05-22-13, 02:23 PM
FLYCT
FLYCT's Avatar
Here's the one in my 2008 SC340
JR
Old 05-22-13, 03:00 PM
ShawnOk
ShawnOk's Avatar
FlyCT, did your SC430 come with the leather wrapped shifter? What year did they start that? I would be interested in changing mine due to tiny "nick" out of the wood from a ring.
Old 05-22-13, 03:43 PM
FLYCT
FLYCT's Avatar
No. That picture was from the dealer site prior to delivery. That shift **** was installed while the car was in the showroom floor. The car was delivered with a wood shift **** just like the one on the 07 picture.
JR
Old 05-22-13, 05:13 PM
liners1
liners1's Avatar
Thanks folks for your help. The culprit is a 2006 with 23,000.
Old 05-23-13, 04:30 PM
mandyfig
mandyfig's Avatar
I guess the 06 has the silver painted bezel.
Old 11-03-13, 10:28 AM
liners1
liners1's Avatar
Default Shift lever bezel removal
Referring to this thread and pictures does anyone have instructions on how to, remove the seat heater controls and the wood frame around the shift lever bezel? Thanks,
Old 11-03-13, 12:14 PM
ShawnOk
ShawnOk's Avatar
It really easy and takes only about 2 minutes. I would start by putting the car into neutral and engaging the parking break. Start by unscrewing the shifter ****. The top part will spin counterclockwise when you're looking down at it from above. Then open the center console so that the lower/deep portion is open. Then slowly and with increasing power try to "tilt" the heater unit forward toward the nose of the car. It should slowly give way and then just wiggle it from the sides to unseat it. There will be a power harness below it, so unclip that. Now you can easily pry the wood trim up using gradual force on both sides equally. Start at the end nearest the heater control and it will pop out once clip at a time. There will be another harness under the middle (near the cup holder portion) and a second harness near the cig lighter. Hope these directions make sense and help you with your project. Good luck.
Old 11-03-13, 04:23 PM
liners1
liners1's Avatar
Thank you SHAWN OK! It is appreciated.
cotswold
05-29-18 07:22 PM
ynctypes
04-20-15 01:40 PM
DjMidas
11-08-12 04:14 AM
chex
SC- 1st Gen (1992-2000)
11-18-10 06:22 PM
mcnelson
GS - 1st Gen (1993-1997)
02-28-03 08:20 AM
Quick Reply: Console transmission shift bezel
