to those that have done their own timing belt
Old 03-21-13, 11:00 AM
fj40ih8mud
fj40ih8mud's Avatar
Default to those that have done their own timing belt
I am midway on the timing belt change out and have two questions.
First, just to confirm that the water pump gasket does not need any silicone on it.
Second, on the idler pulley sub assembly, see below. Can you just replace the bearing? Mine just has some noise, and I hate to pay for another entire part.
Anyone?
Attached Thumbnails to those that have done their own timing belt-photo-d.jpg
Old 03-21-13, 11:22 AM
fj40ih8mud
fj40ih8mud's Avatar
FYI, it is a $300 part. Or $125 Aisen (oem like)
Old 03-21-13, 02:05 PM
thombiz
thombiz's Avatar
I haven't changed mine yet....but I have done a couple Toyota's and YES you can just replace the bearing and save some serious money. On the Toyota's, there was a "C" clip holding the bearing in, remove it and tap the bearing out. Choosing a good replacement bearing is key. By using the number stamped on the bearing, I was able to come up with the exact same number bearing, made in Japan, but out of a Yamaha dirt bike. It was actually the same hardness, etc, but it had better seals to keep the lubricant in and the dirt out. The bearing cost something like $9. Taking it out and putting the new one in took all of about 3 minutes.
Old 03-21-13, 02:40 PM
fj40ih8mud
fj40ih8mud's Avatar
Sweet. Thanks Bob. I will tear it apart tonight and post up some pics.
Old 03-22-13, 08:47 AM
fj40ih8mud
fj40ih8mud's Avatar
Default Fyi not servicable
I had a puller on one side and tried to press it from the other side really gentle. likely 1 ton of pressure with no movement. Well, then it moved across the room....
Aisen part is OEM manufacturer, part FBT-011
Found it on amazon for $110.
Attached Thumbnails to those that have done their own timing belt-img_7162.jpg   to those that have done their own timing belt-img_7155.jpg
Old 03-22-13, 08:50 AM
fj40ih8mud
fj40ih8mud's Avatar
Oh, here is one thing I found...... oops.
Prior owner was a little hard on the curbs.
Attached Thumbnails to those that have done their own timing belt-img_7141.jpg
Old 03-22-13, 09:18 AM
Kira X
美少女戦士セーラームーン
Kira X's Avatar
Yeah, you can just replace the bearing. I got one from NAPA Auto Parts for $12.
Old 03-22-13, 09:24 AM
bb430
bb430's Avatar
I had the same broken under tray or whatever you might call it. I managed to use pieces of black license plate frame and epoxy it back together. I used the 3/4" size binder clips to hold them while the epoxy was curing and drying and left them for a good 3-4 days. Got some screws from AutoZone and now is as good as it can be.
Old 03-22-13, 01:03 PM
fj40ih8mud
fj40ih8mud's Avatar
Cool. Thanks for the advice. I will patch it back together.
wish someone would tell me how to make it look like this.... I am "ok" doing fiberglass.
Attached Thumbnails to those that have done their own timing belt-img_2550.jpg
Old 03-22-13, 01:05 PM
fj40ih8mud
fj40ih8mud's Avatar
Default Yeah, right
I do not think so!
You show me how to get that apart and I will eat my words!
Old 03-22-13, 01:20 PM
thombiz
thombiz's Avatar
I hope I didn't mislead you, the bearings I've replaced are in the pulley on the left side of the sub assembly in your diagram picture. In the diargram, it is referred to as .ssy------------
Old 03-22-13, 01:38 PM
fj40ih8mud
fj40ih8mud's Avatar
I thought with a picture there would not be any confusion about what I was talking about.
No worries.... It was making noise, so needed changed, so from a 20,000 feet view, it was junk anyway and worth a shot.
Old 03-22-13, 02:02 PM
bb430
bb430's Avatar
I think that grille was made from the GS F, I really want to see the bottom of the bumper as how that part was done to connect back to the under tray of our SC's.
Old 03-30-13, 12:55 PM
fj40ih8mud
fj40ih8mud's Avatar
Default powdercoat
Worked on the covers....
Attached Thumbnails to those that have done their own timing belt-img_7156.jpg   to those that have done their own timing belt-img_7320.jpg   to those that have done their own timing belt-img_7324.jpg   to those that have done their own timing belt-img_7328.jpg   to those that have done their own timing belt-img_7331.jpg
Old 03-30-13, 12:57 PM
fj40ih8mud
fj40ih8mud's Avatar
baked on. Now to install them.
Attached Thumbnails to those that have done their own timing belt-img_7330.jpg   to those that have done their own timing belt-img_7339.jpg
Quick Reply: to those that have done their own timing belt
