2002 SC430 chime and light stays on even though top works fine .
Old 06-24-12, 08:25 AM
Toddlevee
Toddlevee's Avatar
Default 2002 SC430 chime and light stays on even though top works fine .
Anyway to turn chime off ? Only chimes when car is moving thanks the retractable hardtop warning light stays on whether the top is fully closed or fully open.
Old 06-24-12, 11:28 AM
Harold57
Harold57's Avatar
First of all, welcome to the forum.
I'm not aware of a way to turn off the alarm.
Since the top still functions, it sounds like the warning light is shorted (or open) in the alarm position. If the sensors that indicate an alarm situation were indicating an alarm situation, the top shouldn't operate. So I'm guessing that there is either a bad connection or a problem around whatever drives the light.
It also sounds like the chime is working properly since it thinks there is an alarm situation and it only chimes when the car is in motion.
However, if the opposite is true that it truly does sense an alarm situation but the top operates anyway, then there is a problem with the top controller.
Typically, the main thing that triggers an alarm is the trunk space divider. (Sorry, I don't remember the proper term.) If the metal pieces that slide down into the slots on each side are not properly seated, an alarm situation will occur. Even if it is fully seated down to the bottom of the slot and the divider is pushed forward too much, its presence will not be sensed and will create an alarm. So the divider being properly seated would be the first thing I'd try. After that, you will likely have to track the problem down.
Old 06-25-12, 06:08 PM
Toddlevee
Toddlevee's Avatar
Default Lexus sc 430
Went to Lexus dealer they said had one code stored B2530 for the package tray limit switch it was not available separate from hunge assembly they wanted 2400$ to fix it. The top works perfect I just want the chime to stop. If anybody can tell me how to disable the chime I will pay you for the info thanks
Old 06-25-12, 06:34 PM
Toddlevee
Toddlevee's Avatar
Default SC 430 will pay for help on this issue
Went to Lexus dealership today to check on retractable hardtop light staying on and chime going off while car is in motion. The code that was stored was B2530 for the package tray limit switch from number 2 need to replace switch but not available separate from the hunge assembly. The top works fine I just need to stop the chime going off anybody can help me on this I would be glad to pay for info thanks
Old 06-25-12, 07:37 PM
Harold57
Harold57's Avatar
Did they show you where the switch is? If you can get a picture of the switch, we might be able to find one that can either replace it that is on the open market or fix it to where it won't make the alarm go off any longer.
Old 06-25-12, 09:00 PM
VVTiBob
VVTiBob's Avatar
First...run away as fast as you can from that dealer and is there another one close to you?
A B2530 error is a malfunction concern the limit switch on the LH luggage lock front, not the package tray. The error, which is most likely the switch, may also be the roof ECU but probably not. We just went through one of these with JohnnyCake's car, but it was another switch...there are several that can fail...I believe his DIY repair cost him about $100, some of his, and Habious' time along with some pizza.
Your part is most like this Diagram. and this $85 part /SWITCH-ASSY--LIMITFOR-LUGGAGE-FRONT-LOCK-LH/5752281/8429024080
Old 06-25-12, 09:05 PM
VVTiBob
VVTiBob's Avatar
If you have access to another dealer I'd get a second opinion ....ARMED with this info to begin with.
Here is the link to Johnny's successful diagnosis and repair...https://www.clublexus.com/forums/sc-...h-removal.html
Old 06-26-12, 08:12 AM
Toddlevee
Toddlevee's Avatar
Default Lexus
Thank you for your help
Old 06-26-12, 08:46 AM
Toddlevee
Toddlevee's Avatar
Default Seat belt chime
I wonder if I could turn the seat belt chime off this would also work for the roof ?
Old 06-26-12, 09:42 AM
VVTiBob
VVTiBob's Avatar
Read this thread https://www.clublexus.com/forums/sc-...ing-chime.html
Try the method suggested and if that does work look through the PDF link in post #14 (numbers are in the top right corner) ....but you really need a second opinion on that 2530 error.
Old 06-27-12, 08:45 PM
Toddlevee
Toddlevee's Avatar
I ordered the switch hope it works thanks to all
Old 06-27-12, 08:51 PM
Toddlevee
Toddlevee's Avatar
If anybody else know any suggestions help please lol
Old 06-28-12, 07:43 AM
bacardi
bacardi's Avatar
bob's advice is most likely going to be right. hes a wealth of info.
Old 06-28-12, 09:36 AM
Toddlevee
Toddlevee's Avatar
Thanks to all
Old 06-28-12, 05:20 PM
Harold57
Harold57's Avatar
Let us know how it turns out. Take pictures if you do some of the repair.
Quick Reply: 2002 SC430 chime and light stays on even though top works fine .
