If Your SC430 Shakes When Starting Engine - You Need New Motor Mounts
Old 04-20-12, 06:50 AM
jasone36
jasone36's Avatar
Default If Your SC430 Shakes When Starting Engine - You Need New Motor Mounts
I have recently had my motor mounts and transmission mount replaced.
Before the replacement, the car would shake quite noticeably when the engine was being started (maybe even shake 'violently'). I thought this was normal until I had my motor mounts and transmission mount replaced. Now when I start the engine the SC430 doesn't shake at all. The difference is profound.
Just a head's up. I'm not sure what the implications are of running with bad motor mounts for a long time, but I decided to get it done because my car would shake when idle and at stop lights.
Best of luck to all.
Old 04-20-12, 07:32 AM
VVTiBob
VVTiBob's Avatar
Glad to read the repair has worked out and you saved a few dollars in the process.
Old 06-28-12, 04:25 PM
2007sc430
2007sc430's Avatar
My car is in the shop right now for new motor mounts due to the start-up shimmying. It usually lasts until the idle calms down. They didn't say anything about the transmission mount though. Luckily it's being covered under the CPO warranty.
Old 06-28-12, 04:48 PM
VVTiBob
VVTiBob's Avatar
There is a known and documented problem with the motor mounts, not so with the one transmission mount. That's most likely the reason it was not mentioned.
Old 06-28-12, 05:15 PM
loudzone
loudzone's Avatar
if you can post the mileage, it MAY help other owners to pay attention. just a thought. and thanks for sharing this info.
Old 07-02-12, 10:42 AM
2007sc430
2007sc430's Avatar
almost 46,000, but it started a few thousand back....
Old 11-21-12, 12:02 AM
dag8882
dag8882's Avatar
recommend anywhere in particular for the purchase of the mounts???
thanks in advance
Old 11-21-12, 08:25 AM
sorka
sorka's Avatar
I'm scared. With the kind of crap I see people posting about on their SC430s going bad at such low mileage, makes me scared about the 2007 we just bought. It only has 12K miles on it, but I was kind of figuring it would be at least if not more reliable than my SC400 which currently has 320K miles on it and has never had a major repair.
Motor mounts went bad at 40Kish miles????? Seriously????
shawnstark
Performance
07-19-19 07:35 PM
DshngDaryl
09-23-17 09:28 AM
DshngDaryl
06-30-17 12:23 PM
fayelawren
02-24-11 10:16 AM
spxChrome
25
09-11-04 11:29 AM
Quick Reply: If Your SC430 Shakes When Starting Engine - You Need New Motor Mounts
