20 inch wheel question
I was going to add a set of 20 inch wheels on my sc, when a friend advised me how wide a gap I will have above the wheel. I'm a novice, I thought the opposite would happen. He said it probably wouldn't look that good unless I dropped it down a couple of inches.I must admit, I was not planning to go thru that expense. Can anyone try to explain how big a gap I'll have or maybe someone has pictures of theres before dropping there car down. Perhaps my best bet is to just stick with 18 wheels.
I just put Staggered 20's on and its great, i get a little rub on a large pot hole/lump in the road but the look is great, I think if you lower the car you will get even more rub and noise and I dont think its that good because there is a nice 2 inch gap between tire and arch, I will post pictures this weekend.
Wheels - Eagle Series 227 (F) 20 x 8.5 and (R) 20 x 10 Staggered
http://www.tiresbyweb.com/p-9380-eag...er-wheels.aspx
As mentioned earlier proper sizing with 20's will give you a wheel/tire combination identical in overall diameter to the OEM's. This will also give you proper speedometer operation.
Check my garage for pics with 20's.
twankys
Wheels, Tires & Brakes Forum
22
03-08-04 05:19 PM
