Rear End Clunk Revisited
Old 10-15-02, 09:53 PM
DropTop430
DropTop430's Avatar
Default Rear End Clunk Revisited
Its been a while since there has been talk of the rear bushing fix for the SC430. I was one who had a very early production date and had the fix done on the rear end. As it turned out I posted and sent my service record and several people noted that the part that the dealer used was indeed a new part but I also found out that there was a newer version of the bushing then the one they used.
The point of my post is that the noise is back in the rear end, initially the fix cured the problem and the car was much more stable and solid over road imperfections. But that day has come and gone.
My question is, have other experienced this?(I seem to remember someone saying that they have been through several sets) and if you have can you send or post the parts numbers used in the fix.
Here are the parts listed for mine
TSB #0489, Ref # RS-01-001R
Re and Re Rear Sub-Frame, Replace Bushings
Parts,
2 Cushion (52271-24060)
4 Exhaust (90917-06078)
Old 10-16-02, 08:47 AM
1NICESC430
1NICESC430's Avatar
I'm dropping mine off today for a bushing and power amp replacement, however, they already sent me a copy of the parts order they placed and received:
52271-24060 Cushion (2)
90917-06078 Gasket (4)
90177-10001 Nut (8)
Old 10-16-02, 06:38 PM
rscharf
rscharf's Avatar
Default How ironic DropTop430!
DropTop430-
I can't believe you brought this up right when I wanted to create a new post about it. Literally, I was logging in to try and dig up an old thread on the topic and there was your thread right on top. I was excited to see the the National Highway Traffic Safety Administration (NHTSA) has recently started posting TSB's in .pdf form so you don't have to order them from NHTSA anymore. They are swamped with requests and it literally takes months to hear back from them.
Here's what appears to be the latest TSB on the matter dated January 18, 2002. (Note that the cushion # is different from what either of you posted.)
http://www.nhtsa.com/TSBScans/sb628659.pdf
The OLD TSB from November 9, 2001 has the cushion part number that you are refering to.
http://www.nhtsa.com/TSBScans/sb627149.pdf
If I'm reading this correctly, everyone with a VIN produced before JTHFN48Y#20022000 should get the cushions replaced. And if I understand the VIN correctly, all 430's built in 2000 and 2001 would need the repair, along with a lot of those built in 2002.
I'm assuming the # sign in the VIN on the TSB is a code for exterior color, which if I'm right, would suggest that the first 2000 of every SC430 in every color built in 2002 would be included in this cushion fix. For example, there is a 4 in my VIN where the # sign is, which probably stands for my Egyptian Sand exterior color.
Someone please correct me if I'm wrong.
Old 10-17-02, 09:01 AM
1NICESC430
1NICESC430's Avatar
Oh, great ... they started replacing mine yesterday with the old bushing part number. When I pick up the car today (or tomorrow) I'll hand the service manager a copy of the first page of the TSB and ask him why the parts department ordered an old part. Cripes - the TSB is dated January!!
Old 10-21-02, 03:16 PM
joeyb
joeyb's Avatar
I'm not sure what's going on here, but my information is that 5227124060 is the second generation bushing used from Jan - Mar 2002 (see TSB SU004-1). 5227130080 is the third generation bushing introduced in April per TSB SU001-02.
But, it is also my understanding that Lexus always sends the latest part regardless of what your dealer orders.
Old 10-21-02, 09:48 PM
Tjz
Tjz's Avatar
I Had my bushings done a couple of weeks ago. They used the third gen bushings, the latest available.
Tjz
Old 11-15-02, 07:39 PM
rscharf
rscharf's Avatar
Default Just Got Bushings Replaced / Front Stabilizer Torqued
Condition: Clunking Sound in Rear Susp
Cause: Rear Suspension Body Mounting Loss of Tension
Remedy: Repair Body Mounting Per TSB# SU001-02
Clunking Sound in Rear Suspension
SU1002 TSB Noise From Rear 4 hours
Part# 5227130080 Cushion, RR Suspension (2)
Part# 9091706078 Gasket, Exhaust Pipe (4)
Part# 9017710001 Nut, Lock (8)
I did not mention the following issue to them, they found it going through the TSBs.
Condition: Popping Sound in Front Suspension
Cause: Front Suspension Stabilize Bolt Loose
Remedy: Retorque Stabilize Bolt Per TSB# SU003-02
Popping Sound From Front Susp.
SU1004 TSB Front Stabilizer Bar 0.6 hours
See Comments on Roof Repair Done at Same Time:
https://www.clublexus.com/forums/sho...399#post444399
Robert
Old 12-06-02, 01:25 AM
SCamp
SCamp's Avatar
Bought my 2002 white gold toy on Saturday (so it rained on Sunday and froze on Monday...) and got the first rear-end KLUNK on the speed bump 50 feet from my driveway. Called the dealer Monday, they said bring it in Wed for service. Then I found this forum -- good reading! -- and so I was all prepared with info, just in case.
Dealer took the car, replicated the problem, called me an hour later with details of what they needed to fix ("Rear bushings, huh, under warranty; good..."), finished it that day.
Oh, and yeah, it was a gorgeous, sunny day, what with the car in the shop.
Thank you for this discussion, & the whole CL forum. Lots of reading the last few days, my first post for my first Lexus.
Old 12-06-02, 11:02 PM
DropTop430
DropTop430's Avatar
Welcome and congrats on the Lexus. I have found this site and board to be very helpful in the past year and a half...Happy Motoring...
Old 06-21-07, 10:26 PM
naked
naked's Avatar
What happens if you don't get this rear-bushing problem fixed?
Old 06-22-07, 06:34 AM
Roofless
Roofless's Avatar
I don't believe it will hurt the car, if you don't fix it. I had it done back then and I thought the difference in clunk levels was pretty slight. Most dealerships back then were aware of the TSB and made the fix without asking the customer.
Have Lexus pull up a service report on your car to see if it was done.
Have fun on your drive to Mpls.
Old 01-02-08, 04:27 PM
UDel
UDel's Avatar
Robert
I have a noise in my GS430 when going over uneven pavement and speed bumps, it sounds like it is coming from the right front suspension and has two sounds, one like a loose peice of thin metal and another one like a squeeking creaking metal sound. I could not figure it out for the longest time. I took it to a Toyota dealership and the did the TSB SU003-02 which was retorque the front stabalizer bar bolts and lubed bushings. It seemed to go away or was much quiter but it is now making the noise again which seems worse in cold weather. This was done about 7 or 8 months ago. I kind of want to try to do this myself as they charged me $45 just to retorque and lube a part. Does anybody have any pictures/diagrams of this and what to do exactly. I don't understand how it keeps working itself loose. They said if that did not work they would try TSB SU004-02 which I think they said would run like $150, hopefully I can take it back and have them retighten/lube because it is still under warranty.
Old 01-02-08, 10:22 PM
da-bizket
da-bizket's Avatar
Good timing with the post. Mine just started making clunking noises a couple of days ago.
I have a 2004 with only 25,000 miles but, may have caused the problem by jacking up the car by the rear end. The technician at Lexus told me it would be OK but the noises started immediately after.
I don't like jacking the car up by the area in front of the rear wheels. I would prefer to raise the car evenly. Once I jacked-up the car on one side, and one of the doors was very hard to close. Not sure if it was due to chassis flex but, I can't think of any other reasons. Don't really want to create flex on the roof, I just got the roof adjusted and roof noise reduced. My Wald kit also reduces the area for a jack and jackstand in the area in front of the rear wheels.
Does anyone have any suggestions for jacking-up the car evenly? Not too many options....
Thanks again,
Mark (da-bizket)
Old 01-02-08, 11:27 PM
Pearlpower
Pearlpower's Avatar
Mark, I generally jack up the rear with the rear end. The Blitz exhaust does make things too low for even my low profile jack so I use a smaller jack to lift a side up a tad and then jack it up the rest of the way under the pumpkin.
Chassis flex is common on cars not just open tops. Almost every car I have owned experienced this.
Old 01-06-08, 12:06 PM
Aristo300
Aristo300's Avatar
Are the dealerships still replacing this for free?
Quick Reply: Rear End Clunk Revisited
