speaker access
Old 09-27-11, 11:53 AM
zneb28
zneb28's Avatar
Default speaker access
Can I get into any real trouble in removing the right hand door panel to get at the speakers?
I'm afraid of breaking a clip or something else that may go wrong.
Old 09-27-11, 12:36 PM
darnot10
darnot10's Avatar
The potential is there. I would have some spares just in case you do.
Old 09-27-11, 12:58 PM
VVTiBob
VVTiBob's Avatar
Most have problems with the two clips pointed to in RED. The trick is to push in on the center and pry out around the outer edge. But the remaining clips are inside and just pop out... Some may drop out of the door panel but they slide back in.
Old 09-27-11, 03:48 PM
cjs18
cjs18's Avatar
This is pretty basic - but one item that could give you problems is failure to disconnect the battery when doing the work. The FSM contains numerous cautions about the SRS system and there may be other risks. It's easy and it could save some money.
orionshoot
05-31-18 01:00 PM
Yurka
05-26-12 03:26 AM
Mr Jokster
02-04-09 01:40 PM
meZoom!
06-15-02 09:05 AM
Shinchan
10-15-01 09:25 AM
Quick Reply: speaker access
