Cold PSI
Old 09-15-11, 04:45 PM
KBALL
KBALL's Avatar
Default Cold PSI
Just wondering what others run their non run flat tires at??
I got michelin pilot a/s plus and run them around 37.
Tire says max 51
Also I'm at about 4000 ft elevation.
Opinions as to optimal psi?
Old 09-15-11, 06:15 PM
jzwu
jzwu's Avatar
Not sure if the elevation has anything to do with the tire PSI.
The recommended PSI is 33 cold. But for run-flats you may want to lower it a bit for a softer ride.
Old 09-15-11, 07:36 PM
sixonemale
sixonemale's Avatar
Tire says max 51
The front door says to inflate to 33 PSI and I'm assuming this PSI is at sea level. Correcting 33 PSI at sea level to 4,000 ft, would about a 2 PSI decrease, or 31 PSI. I run the same tires at around 34 PSI at, or around sea level, give or take a few feet.
Old 09-16-11, 07:12 AM
iolmaster
iolmaster's Avatar
The suggested pressure has nothing to do with elevation. As you have said you lose external pressure as you go up. This means that the internal pressure will go up proportionally. So, going up you let air out. Not add it, to maintain the 33 lb. suggestion.
Old 09-16-11, 07:57 AM
sixonemale
sixonemale's Avatar
Agreed, for about every 1,000 feet of elevation atmospheric pressure decreases by about a half pound.
Old 09-16-11, 08:03 AM
Yes
Yes's Avatar
If you inflate your tires at sea level then drive to a higher elevation, your tires will be overinflated and you'll need to let air out. But if you inflate your tires at elevation, they'll be correct. You don't need to make any adjustments.
kevinisbae
12-02-17 09:32 AM
leg3ndary
07-25-16 09:51 AM
ken987
01-18-13 12:25 PM
ajs
RX - 3rd Gen (2010-2015)
23
05-23-09 04:49 AM
DaveJ
06-09-05 07:02 AM
Quick Reply: Cold PSI
