rear quarter window mod question
What going on everyone. after reading up on the lux link and seeing the mod with the relay i decided to do the relay.I want to know what kind of switch is everyone using for this mod. Thank you
Hi,
Too bad your question didn’t spark much reaction because this is something I’d like to do too.
Like you (and many others in the Club) I would like to be able to lower or raise the quarter windows at will.
I’d like to do this mod but using only existing window switches. (No other switches added).
IMO quarter windows should be either fully up or fully down. No need for “in between”.
Also, quarter windows should only be lowered after the front windows are down. No need to lower the quarter windows only…
This is how I would like it to work;
- Press once the Auto window DOWN button would lower the front window (like current normal operation).
- Once the front window is fully down, press the Auto window DOWN button again would fully lower the quarter window.
Quarter window could only be lowered if the front window are fully down.
- Press once the Auto window UP button would raise the quarter window first.
- Once the quarter window is fully up, then the front window would be controlled like usual…
Any thoughts?
Any thoughts?
I have this its just a basic 2 way switch from an alarm. It doesnt have an external switch. Its connected to your driver side window. Tap it 3 times and it rolls down your 1/4 windows. You always tap to open. Always open your windows and close them after your 1/4 or it will rub the seals and wear them prematurely. Also whenever you use this mod your top will not open or close until you resart your car. If you try to open the top with the windows down it will think these a problem and not open just a bug that nobody seems to mention
i have this its just a basic 2 way switch from an alarm. It doesnt have an external switch. Its connected to your driver side window. Tap it 3 times and it rolls down your 1/4 windows. You always tap to open. Always open your windows and close them after your 1/4 or it will rub the seals and wear them prematurely. Also whenever you use this mod your top will not open or close until you resart your car. If you try to open the top with the windows down it will think these a problem and not open just a bug that nobody seems to mention
I did the relay mod, you need a SPDT (single-pole, double-throw) (On)-Off-(On) switch. The parenthesis around the On designates that it's momentary, that is, the switch naturally returns to the middle/Off position. Like this one: http://www.ace4parts.com/Products/Ro...)__30-965.aspx
That is very similar to the switch that I used; except that one looks a little longer/narrower than mine.
Mine is mounted on the top of the coin tray in the center console. Looks very nice and is really out of the way.
Some guys have mounted them near the seat-heater switches but I could not get the switch that I bought to look good there; I would have had to go to a much smaller switch & could not find one; and did not want something really tiny.
Jerry Baumchen
This is a duplicate from my post in the "other" quarter window mod thread...
"After carefully reading (over and over) Lexiss SC430’s instructions, I came up with what I believe is the “long awaited” wiring diagram for the quarter window mod."
Lexiss SC430, please feel free to verify and confirm the accuracy of this diagram and thanks for detailed instructions.
As mentioned in one of the above posts, the switch must be a "Momentary on-off-on" type.
Download the PDF file for clearer image.
