SC has any problems on convertible top?
I feel that there are a few keys points to keep in mind about the top function. I've had my 2002 for going on 13 years now (7 miles on delivery), only owner, and never had a problem with the top; ever. In the past I always tried to keep in mind that if the trunk gets too full it will put stress on the forward alignment arms, so never fill the trunk to extremes where you have to force the trunk to close. Once every 6 month, I tighten all the accessible bolts and screws along the guide arms. I also put some WD40 or lubricant along the friction/hinge points. Additionally, as explained above I rarely drop the top without the engine started. I've read that if the computer that controls the top loses power midfunction, it can cause serious problems. I'm not sure if these tidbits are actually helping or not, but in 13 years and living in Oklahoma and Missouri for most of it and always flying top down, never had a problem. Fingers crossed, of course.
Since we don't use the car much , there really hasn't been much put in the trunk. I'll try WD40 on the moving parts, but I think there is another. As I stated before, if you disconnect and reconnect the battery if will work at least once. There must be another issue. Has anyone else had the same issue? Please advise.
Thanks
Thanks
I had a Boxster before, the convertible top had a problem.
while I took the car to dealer, I found all the Porsche convertible have the top's problem, boxsters and 911s sitting around....
cost $2k to fix it, afraid to open the top after that, coz that day, I needed to put my head all the way down, while I drove home with the Boxster with the failure top (stop in the air)... shame
thinking to buy a SC, anyone knows if the SC has any top's problem?
I just want to ask again, if anyone who has owned a 2002 430SC has experienced issues with the top going down. When we push the down button we hear a click, but the top doesn't go down. If I disconnect and reconnect the battery it seems to reset the system and the top will go down and back up. When I try to put the top down again all we get is the clicking sound when the down button is pushed. Any help or recommendations would be greatly appreciated.
You can also check to see if it is putting out any error codes. The dealer can do that also.
lexus!!!!!
06-07-10 12:14 PM
