antenna not retracting
Old 08-07-10, 01:21 PM
Drabek
Drabek's Avatar
Default antenna not retracting
The antenna on my '02 stopped retracting the final one foot. When I turn the car off I can still hear what I think is the retraction motor 'buzzing' for 10 secs. I cleaned it and oiled it with liquid graphite and I can pull it out and push it in manually.
Do I need a replacement? Can my Toyota dealer do it?
Thanks
Chuck
Old 08-07-10, 01:45 PM
1NEAT_SC
1NEAT_SC's Avatar
Drabek, that sounds identical to the problem I was having. I removed the antenna myself only to find about 5" of plastic which obviously came out with the antenna mast. The rest of the plastic is still in the motor the best I can tell. So tomorrow's project is to access the motor to see if I can get to the remaining plastic mast worm or whatever it's called. If you're lucky you may just have a few teeth missing on your plastic mast. Then all you have to do is pick up a new one and follow instructions on another thread.
good luck,
lar
Old 08-10-10, 12:10 AM
Wesssup
Wesssup's Avatar
When I first got my SC, I had the same problem. I just took it to an audio shop and had them fix it, cost me like $20.
Old 11-08-10, 12:11 PM
Jace_91
Jace_91's Avatar
1NEAT, how did it go getting to the motor? I removed my old mast, and ran into the same problem, I'm some( or most) of the old cable is still in the motor
Old 11-08-10, 03:45 PM
jimmer!
jimmer!'s Avatar
coat hanger?
Old 11-09-10, 02:07 PM
tromly
tromly's Avatar
Boy did you ever get off dirt cheap
Old 11-09-10, 05:17 PM
rclab1
rclab1's Avatar
same thing happen, my dealership told me that the "antenna cable is broken in motor"?
GWS
GS - 1st Gen (1993-1997)
02-28-11 03:59 PM
horent135
SC- 1st Gen (1992-2000)
02-13-11 09:31 PM
Bobk528
RX - 1st Gen (1999-2003)
10-01-09 10:28 AM
mdfdsc300
04-19-01 03:07 AM
Quick Reply: antenna not retracting
