Finally decided to change my 6x9s - Any suggested 6.5 speakers?
Old 02-01-10, 08:30 AM
daryltrinh
daryltrinh's Avatar
Default Finally decided to change my 6x9s - Any suggested 6.5 speakers?
While I'm waiting for my sub to be swapped out (previously Earthquake SWS-8, probably gonna be a Fosgate P1 next).
I finally talked myself into changing out the ML 6x9s in my doors.
Can anyone suggest any 6.5 woofers that have great bang for buck?
There's a heavy selection at http//www.parts-express.com
Gotta consider the 3" +/- mounting depth, 8-ohm impedence (if you're using the ML amp), and as well as the frequency response range.
I just ordered a pair of adapters from this site for about $15.
http://car-speaker-adapters.com/
Thx guys.
Old 02-01-10, 04:45 PM
Peter_Klim
Peter_Klim's Avatar
Gotta consider the 3" +/- mounting depth as well as the frequency response range.
Thx guys.
If they're not too deep, get some Dynaudios. 2nd choice would be Focals. then maybe Boston Acoustic Pro series (if they still make them) But nothing touches the Dynaudios.
Old 02-01-10, 07:07 PM
daryltrinh
daryltrinh's Avatar
Thx for the suggestions.
Can we keep it under $100 a speaker?..
Old 02-02-10, 06:58 AM
PHXSC
PHXSC's Avatar
Here's one of the best write-ups ever on replacing speakers. Hope it helps!
https://www.clublexus.com/forums/lex...all-sc430.html
Old 02-02-10, 09:00 AM
daryltrinh
daryltrinh's Avatar
Thx PHXSC,
but I've already read this write-up.
Unfortunately, ZGone doesn't provide a parameter of specs that you should look for when selecting your speaker replacements.
Old 02-02-10, 10:15 AM
PHXSC
PHXSC's Avatar
Thx PHXSC,
I dug around for another thread I remembered reading, but couldn't find it, as it was a while ago.
Someone found the correct impedance speaker - not car audio, but home speakers, and modified the mounting to fit.
The speaker also fit the 3" depth limitation.
Old 02-02-10, 11:05 AM
daryltrinh
daryltrinh's Avatar
Definitely caught that part.
Any other recommended specs?
Freq response range?
Xmax?
Etc..
Old 02-02-10, 03:29 PM
drsaab1
drsaab1's Avatar
someone posted that they put these in and they worked well.
http://www.parts-express.com/pe/show...number=290-400
Old 02-02-10, 04:54 PM
tfeni52355
tfeni52355's Avatar
I used these. They are outstanding. Discontinued but check the specs
http://www.parts-express.com/pe/show...number=297-305
Also check this link to the whole story and directions etc. Don't skimp! Put the EDead in for sound in the doors and back of seats in rear if you do the drivers and sub in rear.
I did the fronts in May of '09 and the rear over Christmas.
https://www.clublexus.com/forums/sc-...ml#post5149521
Worth every penny and minute I spent doing it!
Old 02-02-10, 05:13 PM
Alterious
Alterious's Avatar
are you changing the deck and the amplifier or just the speakers? Because i recently replaced my subwoofer behind the back seat and i had to find a 10" with 16 ohms. Every car audio place i went to told me that i had to replace with with a 16 ohm speaker otherwise the factory amp would burn because of the power distribution.
This setup looks awesome, i'd like to do something like this
http://www.youtube.com/watch?v=Ypa6ZWpEfrY
Old 02-02-10, 09:23 PM
daryltrinh
daryltrinh's Avatar
Most would just hook up a 4-Ohm with an additional amp.
I had my RF R500-1 tucked in the spare tire kit,
completely hidden.
Old 02-02-10, 10:00 PM
Alterious
Alterious's Avatar
completely hidden.
do you have pictures?
Old 02-03-10, 01:17 PM
daryltrinh
daryltrinh's Avatar
Here you go:
https://www.clublexus.com/forums/5011450-post9.html
Old 02-04-10, 03:49 PM
tfeni52355
tfeni52355's Avatar
May sound silly, but how do you mount your spare tire now?
Old 02-04-10, 05:45 PM
daryltrinh
daryltrinh's Avatar
No spare tire.
I think I'll go with some Dayton 6.5" woofers as well as some Dayton 3" full range speakers.
Any opinions anyone?
Quick Reply: Finally decided to change my 6x9s - Any suggested 6.5 speakers?
