"noise" when changing radio stations
Old 05-01-09, 04:50 AM
430-4-ME
430-4-ME's Avatar
Default "noise" when changing radio stations
Does anyone hear a sound coming from the right rear side when changing radio station presets (stock ML, no mods)? It sounds like the DVD in the nav system spins when I change the radio. Only for a second or two, bur clearly audible and never again until I change the station. Never noticed it in my ES w/ML and Nav.
Old 05-01-09, 05:11 AM
JohnnyCake
JohnnyCake's Avatar
That is the antenna automatically lengthing or shortening to achieve the best length for the frequency of the radio station to which you are listening.
Old 05-01-09, 07:41 AM
mrblister
mrblister's Avatar
Johnny I thought the antenna moved up or down when switching from AM to FM I was not aware that if you were on FM that the antenna would raise or lower from FM station To Fm station
Old 05-01-09, 08:10 AM
Yes
Yes's Avatar
nope. it moves when you simply change stations. give it a try
Old 05-01-09, 08:17 AM
tfischer
tfischer's Avatar
I believe it has 2 FM positions, and will change when you go from a low frequency station to another FM station in the higher half of the dial. I do not think it changes length when you change stations that are close to each other on the dial (but I might be wrong on this).
boxcarfan
GS - 1st Gen (1993-1997)
08-19-10 09:51 AM
caddyshack
03-17-10 08:33 PM
petergerst
11-17-06 09:50 AM
shpritz
07-29-06 08:40 AM
kevin333k
02-25-04 07:42 PM
Quick Reply: "noise" when changing radio stations
