Help with SC Phonebook
My cell phone automatically blocks Caller-ID for all outgoing calls. However, some people I call will not accept callers who block their numbers. For those people, I must dial*31# before the number to remove the block.
I have a contact entry in my cellphone which has the unblock code before the number (e.g. *31#2024561414). When calling from the cellphone contact, it works just fine, the caller-id is unblocked and the call goes through.
I uploading that contact to the SC phonebook and it appears correct (e.g. all numbers and characters are listed). But when calling using the SC phonebook, the caller-id is still blocked and so the call can not go through.
So the exact same number is treated differently depending on whether the call originates with the cell phone or the SC.
This must have something to do with how the SC dials calls versus how the cell phone dials calls. Any insight appreciated.
cell phone
Hi Johny
Why dont you try and see if you can dial number through the manual entry of the number from the navigation screen. If it works then you may need to enter a space between *31# and the number your calling. You may need a pause between the un block code and the number you are dialing. Try it
Buddy
I thought I read that you can place a pause in the sequence so that when you dial a prefix or a special numeric group the pause is needed so the number you are dialing can see the pause before the number completes. It sounds funny but I remember that I had to enter in a series of ** on an answer machine dial out so that the phone i was reaching would have a chance to see it first.
KInd of like dialing a bank number and then a pause to enter in your pin.
I could just be imagining this
Buddy
JohnnyCake
09-12-10 03:03 PM
margaux01
03-17-09 06:27 PM
JohnnyCake
12-16-08 01:15 AM
