VSC lights: where are the wheel sensors?
Old 07-03-08, 12:08 PM
ratha67
ratha67's Avatar
Default VSC lights: where are the wheel sensors?
Well my VSC warning lights came on yesterday. I read the other threads on this and apparently it is probably the wheel sensor. My front tires have a tendency to rub the wheel wells on tight turns (20 inch rims), so that might have something to do with it.
I know the wheel sensors (speed sensors, ABS sensors, whatever they are called) are in the wheel well area, but what do they look like? how do I get to them? and how should I troubleshoot them?
I'll try to get the codes (if any) pulled (autozone will scan it for free I hear, or I'll pick up an OBDII scanner). If it does tell me it is the wheel sensor, is this something where I can clean off the sensor, or maybe hook up a multimeter and check resistance to see if it is a good sensor? A quick step-by-step DIY troubleshooting would be much appreciated.
Thus far, I have unplugged the negative terminal of the battery to see if the lights will come back. so far 25 miles and no lights....yet. As much as the wire trick mentioned on the other thread (connecting jumpers of the OBDII port with a wire to reset the light) sounds interesting , I haven't done it yet. Anyone want to fill me in anything else it could be...maybe this whole thing about resetting the Yaw sensor?
Also, on a separate issue, prior to unplugging the battery its been idling really rough (usually noticeable at a red light). I'm going to get some throttle body cleaner and give that a shot, probably put some fuel injector cleaner into the gas tank, and maybe hit the MAF sensor with some electronics cleaner. Any other tips?
Thanks.
Old 07-04-08, 10:19 PM
CAMAracer
CAMAracer's Avatar
Edit* Opps, hehe. I just typed "tpms wheel sensors" into google and got those pics. Didn't even bother thinking about whether it was the correct images :P
Old 07-04-08, 11:36 PM
Pearlpower
Pearlpower's Avatar
The above pics are the tire pressure sensors, not wheel sensors. The wheel sensor is a long (18" or so) that runs from the wheel hub assembly to the car. As it is most likely a front sensor when you look at the strut assembly you will see the cable attached to it with a 10mm bolt. It takes a little digging to detach it from the inside as it is behind a few plastic shields but very doable.
See it in the lower left on the picture below
Attached Thumbnails VSC lights: where are the wheel sensors?-img_4541-custom-800x600-.jpg
Old 07-05-08, 08:25 AM
ratha67
ratha67's Avatar
Thanks for the info. As soon as I get an ODB-II scanner, I'll update you guys on the codes found. My car has been idling really rough and even sputtering on the freeway when I am off of the gas. Would a faulty wheel sensor cause that? Right now, the warning lights that are on are VSC, VSC Off, and Check Engine. Those lights came back after unplugging the negative terminal of the battery and driving it about 40 miles.
I have thus far poured Red Line Complete Fuel System Cleaner, Sprayed my MAF sensor with CRC electronics cleaner, and used CRC throttle body cleaner and a rag to wipe off the throttle body and the butterfly valve. Why do I still have the intermittent sputtering and rough Idle, unplugging the battery m aybe?
Thanks.
Old 09-07-08, 09:37 PM
siriancj
siriancj's Avatar
I am having the same issues with my 1998 GS400. VSC lights are on and it runs alittle rough at times. I am going to pull the codes. I am wondering if you were able to pinpoint the issue and know the fix.
Thanks Chris
Old 09-08-08, 04:45 AM
tfeni52355
tfeni52355's Avatar
Default Manuals?
Pearlpower,
I would love to get a set of manuals for my '02 SC. Can you tell me where you got yours in the picture ?
Thanks
Old 09-08-08, 08:16 AM
ratha67
ratha67's Avatar
Thanks.
Just an update. I fixed this awhile ago. I had a misfire (code PO306- cylinder 6 misfire) caused by a bad connection in the wiring for the cylinder 6 fuel injector. The plug just jiggled loose and I just had to unplug it and plug it back in making sure it was a secure connection. I guess when there is a misfire, those 3 warning lights pop up on the dash. Nothing to do with the wheel sensor this time.
Hopefully if anyone else has a misfire issue. This will serve as a quick diagnostic guide.
To diagnose it, I first checked all the spark plugs. Swapped spark plugs to see if the misfire would follow to another cylinder. Still cylinder 6 misfire.
Then checked the coil packs and swapped them to see if the misfire would follow to another cylinder. Still cylinder 6 misfire.
Then checked the fuel injectors to see if they were working. Using a long screw driver, I put one end against the fuel injector and the other end against my ear (make-shift stethoscope) to listen to each fuel injector individually. Thats how the bad fuel injector was discovered. Then by acccident, we found out it was the wiring rather than the injector itself, so we didn't have to swap fuel injectors to see if the misfire would follow to another cylinder.
No more misfire, and all is well.
Old 09-08-08, 08:26 AM
intdiamond
intdiamond's Avatar
Originally Posted by tfeni52355
Pearlpower,
Thanks
Lee's got them for sale here:
https://www.clublexus.com/forums/sho...d.php?t=376045
(Lee- I'll take a 5% commission for the referral.... )
fdibugnara
05-05-17 07:53 PM
Bworley626
04-02-14 12:12 PM
jbrandon
Suspension and Brakes
06-30-13 07:32 PM
fltfndr
03-12-12 01:05 PM
qlex56
03-25-07 08:12 PM
Quick Reply: VSC lights: where are the wheel sensors?
