Ride Quality with 20" Wheels
Old 04-08-08, 02:13 PM
oldhotrod
oldhotrod's Avatar
Question Ride Quality with 20" Wheels
I'm trying to get some input on the ride quality of 20" wheels with 245/35 tires as compared to the original 18" wheels with the dreaded 245/40 Run Flats. I really like the looks of the 20s but don't want a "buckboard" ride. I figure 19" with 245/40 non-run-flat regular tires have to be better than the 18" 40 series run flats, but I'm wondering how you guys running 20s would compare your ride quality to the O.E.M. Run-Flats?? I've searched all the available threads on this, but I'd like some current input and maybe a suggestion on what brand/model of currently available tires would make for the least annoying ride, with 20s, from your experience. This is my second SC, the first one I just went the easy route with 245/45-18s and that was a MAJOR improvement over the Run-Flats, but on this one I'm feelin' bigger wheels!!!--- Help me make the right decision!
Old 04-08-08, 02:40 PM
Lexiss_sc430
Lexiss_sc430's Avatar
Search….
https://www.clublexus.com/forums/sho...with+20+wheels
Old 04-08-08, 03:06 PM
oldhotrod
oldhotrod's Avatar
Smile
Thanks for the Quick response, But maybe you missed the part of the original post that said:
"I've searched all the available threads on this, but I'd like some current input and maybe a suggestion on what brand/model of currently available tires would make for the least annoying ride, with 20s, from your experience".
Old 04-08-08, 04:43 PM
Lexiss_sc430
Oh sorry about that, here are some posts that will help.
https://www.clublexus.com/forums/sho...d.php?t=343215
https://www.clublexus.com/forums/sho...d.php?t=347563
https://www.clublexus.com/forums/sho...d.php?t=290431
Old 04-09-08, 05:52 AM
bt430
bt430's Avatar
Ride quality is going to depend on how much you change things up. Bigger wheels, lower profile tires will stiffen up the ride a bit. If you plan to lower the car choice of springs/shocks or coilovers will impact ride quality more. That's where I think the problem may lie for you as once you get the 20s on and see all that room between the tires and fenders you're probably going to want to lower it.
Old 04-09-08, 06:36 AM
Addiction2
Addiction2's Avatar
I changed only my wheels to 20's, no suspension changes. My ride quality has not seemed to suffer, until I hit a rather nasty bump or pothole I cant tell the difference.
Old 04-09-08, 04:04 PM
Aristo300
Aristo300's Avatar
19's with a decent profile should ride better than the stock run-flats. My favorite tire out right now is the Falken FK452's.
Old 04-11-08, 08:58 PM
Yes
Yes's Avatar
i went from stock runflats today to 20s with toyo tires. the ride quality is drastically better. don't have much experience with other tires to compare them to, but they're pretty reasonably priced.
Lexus88
04-18-18 11:02 AM
music6890
06-09-13 08:35 PM
TitanFan
08-23-12 09:38 AM
sld
Wheels, Tires & Brakes Forum
25
09-22-07 12:20 AM
photoguy
11-01-06 06:50 AM
Quick Reply: Ride Quality with 20" Wheels
