SC430 wheel spacer/adapter Advice
Old 04-08-11, 01:41 PM
  #91
robertrios
robertrios's Avatar
mine are is250 wheels so my rears are wider than stock by a half inch so maybe 25 front and 30 rear for me?
Old 05-15-13, 04:39 PM
  #92
ferrarilon
ferrarilon's Avatar
Is it me or H&R does not offer 30mm any longer?
Old 05-15-13, 05:20 PM
  #93
bacardi11
bacardi11's Avatar
245x40x18 tires I use 19mm front and back.
Old 05-21-13, 05:45 AM
  #94
scyul
scyul's Avatar
When I ordered mine, 30mm spacers were not listed for the SC, but I found them for the RX... That's what I used.
Old 05-21-13, 06:41 AM
  #95
mandyfig
mandyfig's Avatar
I used 35's off fleabay.
Old 06-27-13, 12:07 PM
  #96
Alex818
Alex818's Avatar
For those of you who come across this and are looking for spacers. The widest I've found are 38mm and here's the link
http://www.ebay.com/itm/HUBCENTRIC-BOLT-ON-38MM-WHEEL-ADAPTER-SPACERS-PATTERN-5X114-3-CB-60-1MM-12X1-5-/181078690298?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ASC430&vxp=mtr&hash=item2a292189fa
Old 06-27-13, 06:24 PM
  #97
mandyfig
mandyfig's Avatar
Exactly what I have and the same price, too.
Old 08-11-13, 05:33 AM
  #98
Autoplak
Autoplak's Avatar
Great info and thanks to all.
If you can help with advice. I am going to install aftermarket wheels with an 35 offset and stock suspension and tires of 245/40/18.
Wheels with adapter rings will be the 60.1 hub bore.
Does 25mm front and 35mm rear spacers work?
I figure that the 25 front plus the 35 offset in the wheel is 60 or 15mm out from stock. Same math for rear only 25mm more than stock.
Is my math correct?
Old 08-12-13, 05:13 AM
  #99
Autoplak
Autoplak's Avatar
I assume that mandyfig has been running Hubcentric's 25 front and 35 rear spacers for about 2 years of this thread with no problem. I am about to place the order for the same and I would appreciate comments on my logic / math in my previous comment. I am a noob to spacers / aftermarket wheels.
Am I correct?
Old 08-13-13, 12:24 PM
  #100
Autoplak
Autoplak's Avatar
Thanks,
I did the math wrong. Inverted thinking. 35mm offset will push the wheels out 10mm from the stock 45mm. With that I've decided not to install spacers.
Old 08-19-13, 09:00 AM
  #101
marty99
marty99's Avatar
Default What brand spacers
What brand spacers did you get, and did you have to modify the wheel bolts to fit? I'm about to do the same project on my SC430 with IS350 wheels. Thanks, Marty.
Attached Thumbnails SC430 wheel spacer/adapter Advice-sc430-01.jpg
Old 07-04-16, 09:54 AM
  #102
bobster99
bobster99's Avatar
Default SC430 wheel spacer/adapter Advice
I have been talking about doing this for quite some time and I finally broke down and bought the spacers. I went with eBay, I know, everyone always is suspect of the quality of eBay and I was certainly not looking forward to sending back the adapters if they shook.
I was so concerned that they would vibrate that I put the the spacers one at a time and took it out for a test drive after every wheel was reinstalled. Even at 80 mph I didn't notice any vibration at all.
I am using OEM 2007 SC-430 rims on the car so I installed 25mm (1") on the front and 35mm Hubcentric Wheel Spacers on the rear. This is my only experience with the suppliers on eBay but they shipped really quickly so if you would like to know who I got them from just PM me.
Although it may be just be in my head increasing the track a bit does seem to make the car handle better. It isn't like I am driving on expensive tires and there is no way that the SC430 is anything I would take to a Pro Solo event but still, it does feel better.
I took some photos to show the improvement in looks.
Front Before
Front Afterwards
Rear Before
Rear Afterwards... Mr2 sure looks small compared to the SC doesn't it
Side shot before
They just fit better, I have no idea why Lexus didn't do this from the factory.
Old 07-04-16, 11:24 AM
  #103
farkas
farkas's Avatar
@ bobster99. Looks good! I ran the 25-30 mm setup for years with OEM wheels till I upgraded to aftermarkets with the proper offsets and now I don't need them. <br > <br >
Old 07-04-16, 12:23 PM
  #104
texsexlex
texsexlex's Avatar
...nice looking wheels Farkas......what brand, size & offsets ?
Old 07-04-16, 12:41 PM
  #105
farkas
farkas's Avatar
@texsexlex.
Volk Racing GT-AV in Silver
(2) 19x9.5 +17, A-disk (high pad)Front
(2) 19x10.5 +24, C-disk (low pad)Rear
Quick Reply: SC430 wheel spacer/adapter Advice
