one window won't listen to switches
Old 12-07-07, 10:48 AM
bfigard
bfigard's Avatar
Default one window won't listen to switches
Anyone ever have this issue?
Passenger window goes up and down with the top when activated via the up/down button the on dashboard (along with the driver's window, as it is supposed to).
Driver window works fine with the window switch on the door panel.
Passenger window will not move up or down when either the driver's side switch or when the passenger's side switch are pressed.
Both the fuses "P-DOOR" and "D-DOOR" are fine.
LuxLink remote top activation also works fine and activates windows up/down with top as well.
The only possibility I can think is that window switch wires spliced during LuxLink install have fallen out of their splice...any other ideas?
Old 12-07-07, 02:11 PM
Habious
Habious's Avatar
Really stupid question but, someone's gotta ask it. Is the "Window disable" switch on the driver's door pressed?
Old 12-07-07, 02:21 PM
bfigard
bfigard's Avatar
Not a stupid question. Stupid problem.
Tear up my Engineering degree and my MBA, and never tell a soul that I used to work on telemetry for Indycars.
That switch was completely "invisible" to me and I had no idea what it did.
Call me Homer... Think I'll go play with my spiderpig now.
Old 12-07-07, 03:00 PM
Habious
Habious's Avatar
Well, at least it was a simple fix! Imagine if you'd gone to the dealer with that problem!
Glad that's all it was.
Old 12-07-07, 03:34 PM
bfigard
bfigard's Avatar
Yeh, the charge would have been $105 (the approx minimum for just glancing at it while it is in the shop).
The aggrivating part, though, would have been waiting 4 days for them to look at it because they saw new OEM parts that were not installed by them.
"Bottom of the priority list for this guy; he gets the expensive stuff done by some other shop."
dr.300
02-19-10 02:39 AM
edgy
RX - 1st Gen (1999-2003)
02-02-10 12:00 AM
omarston
Maintenance
06-17-09 09:20 AM
pwesseler
12-11-08 12:35 PM
SloGS3
07-27-06 12:57 PM
Quick Reply: one window won't listen to switches
