How to change rear brake pads on 2002 SC430?
Has anyone done it? I searched CL but only found instructions for 2004 LS430. Any help will be appreciated.
exclusive matchup
did you try to do a search on the 2gs? they are the same setup.
it's hard to describe here, but it's very simple. if you look at the caliper, at the top it's basically a metal clip. you slide it one way to loosen it, and then the two pins holding the pads can come out. after that it's trivial
SSK0771
06-20-05 01:39 AM
