Up date SC430 2007 style
Is any one has been up date `02 ~`06 SC430 to `07 SC430 Headlight?
I have wondering Adaptive Front lighting System (AFS) wiring.
If any one has suggestion or what I did, let me know!
= Example =
2007 Headlight install to W/o AFS SC430.
ThanX,
= Example =
ThanX,
2007 has same headlight unit shape, but lens arrangement of internal design is different.
My question was install 2007 Headlight to my W/o AFS 2002 SC430.
Actually 2006 and 2007 are the same. As for your question, You will lose the AFS and the Auto level. You can swap the headlights and the power plugs on the ballasts will line up. You headlight swap is doable but like I said you will lose the AFS of the 2007 headlight and you will lose you auto level in your sc430. Im looking for a 2006+ wiring diagram to see what the wires on the level motor do. The new motors use 4 wires the old one uses 5 or 6. There both ASMO motors. I tried to swap them but the newer ones run a little deeper into the headlamp.
