knock sensor ??? or ecu...
Old 10-30-06, 06:03 PM
mikep34689
mikep34689's Avatar
Default knock sensor ??? or ecu...
i have a 2003 sc 430 supercharged, i recently got a po 325 code [ knock sensor ] i was wondering if any one else ran into having to replace one after 44000 mile ? every one i talk to including lexus say they dont go bad,,, could it be the ecu... once the knock sensor sets the code the lights come on in a litte pretty string, [ engine ] and both [ vss ] lights. also timing stays retarded, and dont reset it self till the code is cleared,, any in sight?
Old 10-30-06, 06:14 PM
mikep34689
mikep34689's Avatar
Old 10-30-06, 06:15 PM
mikep34689
mikep34689's Avatar
Default Ecu Or Knock Sensor????????????
Posting Rules
You may post new threads
You may post replies
You may post attachments
You may edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Old 10-30-06, 06:35 PM
Pearlpower
Pearlpower's Avatar
What type of engine management are you utilizing in your setup?
If the timing is always set back as you stated, sounds as if it need some tuning to bring things back into order.
Old 10-30-06, 07:09 PM
sc430blue
sc430blue's Avatar
What plugs are you using? I would get that code when I would try colder plugs. The piggyback took care of that.
Old 10-30-06, 11:50 PM
JPI Racing
JPI Racing's Avatar
You will rarely see the knock sensors go out on the Lexus vehicle. Make sure the wires aren't cut or the connector came out when installing your s/c. BTW, this is your bank 1. If you have access to a Lexus scanner, I would take a look at the voltage of your knock sensor on bank 1. What s/c are you running? Engine management?
JPI
Old 10-31-06, 07:54 AM
mikep34689
mikep34689's Avatar
procharger c-2 - i-manage, s-s headers, denso 22 plugs, i have had it on for abought a year now with no problems, the code just poped up one day . i checked the harness going to the sensor and its o.k. i"m wondering why it will not set the timing back to where it is suppose to be after the code ? thats what leaning me toward the ecm, i dont want to just throw parts at it to fix it. any help would be cool....
Old 10-31-06, 10:09 AM
Pearlpower
Pearlpower's Avatar
Hi Mike
The 0325 code is a no signal error from the knock sensor error. Though rare, they do go out. Two choices, ECM is bad or knock sensor is bad or wiring is loose. What type of piggyback A/F unit are you using? If it is wired into the knock sensor circuit I would look there first and check all connections and/or resolder them.
Old 10-31-06, 10:54 AM
mikep34689
mikep34689's Avatar
the i - manage is a controler that is not connected to the ecm, its a feul pump that only comes into play under boost. i can set the code just tipping the gas pedal slowly between 2200 2500 rpm sitting in the garage NOT under any type of boost or load, according to my wide band o2 it idles at around 14.5..a/f under boost i have it running fat abought 10.00 to 12.00 a/f pulled plugs both sides look fine. i would hate to remove the plentom to replace the sensor and not be it. any way you know of to check the ecu ? i heard or over sensetive sensors but never ran into it before.
Old 11-01-06, 07:20 AM
mikep34689
mikep34689's Avatar
anbody out there here of anything like this ????????????
Old 11-01-06, 09:25 AM
Pearlpower
Pearlpower's Avatar
Mike
Shoot me a pm with your email addres that accepts attachments so I can get the prodecure out to you.
Lee
Old 11-01-06, 03:55 PM
mikep34689
mikep34689's Avatar
did ya get that ?????
Old 11-01-06, 04:07 PM
JPI Racing
JPI Racing's Avatar
Mike,
Do you have access to a scanner? You can read the knock voltage off it.
JPI
Old 11-02-06, 05:31 AM
mikep34689
mikep34689's Avatar
yes, snap - on. went into data stream and nothing for knock sensor voltage, went on alldata and there diagrams are wrong, i think i wasted enough time , im going to replace the sensor today and see whats up, i will let you guys know if it works, thanks for all the input, mike....
Old 11-03-06, 08:19 AM
mikep34689
mikep34689's Avatar
to all the lexus dealers out there that say the knock sensors dont go bad you are wrong, back up to 6 p.s.i. and no codes so far, i would like to thank every body who answered my post and gave me input i thank you. mike
Quick Reply: knock sensor ??? or ecu...
