Supra Twin Turbo brakes install on SC430
Old 08-26-14, 09:55 AM
  #46
fj40ih8mud
fj40ih8mud's Avatar
Bimmer --
Thanks brother!!!!! Owe you a drink.
Will update when I get them replaced.
Cheers!
Old 08-26-14, 10:02 AM
  #47
fj40ih8mud
fj40ih8mud's Avatar
Just looked up that part number, and not finding it as stoptech.
Could it be 128.44104R? and 128.44103L?
Also, looking up 97 supra twin turbo. Looks like standard brake rotor is cendrix with your number 120.44103 and 4
Old 08-26-14, 02:33 PM
  #48
416tt
416tt's Avatar
Hi fj40ih8mud,
My apologies that's right got mixed as I ordered 4 sets of brakes at the same time.
I ordered 128.44104R and 128.44103L. as for the stop tech brake pads my only complaint is the brake dust. I should've got ceramics, otherwise the bite is great
Good luck. Let us know how it goes!
Old 08-27-14, 07:24 AM
  #49
fj40ih8mud
fj40ih8mud's Avatar
Thanks again. Just ordered the new set of rotors....
Old 09-03-14, 01:22 PM
  #50
fj40ih8mud
fj40ih8mud's Avatar
Bimmer, thanks again. Got it all installed this weekend, but needed 3.5mm spacer, so ordered some 5mm spacers. Took several pictures, so will get them posted up.
Old 09-03-14, 01:49 PM
  #51
fj40ih8mud
fj40ih8mud's Avatar
Default pics
here are pics. I tried to take reference pics so all know how much to trim off backing plate. I cut too much off, could have just done 1/4 inch on top on the inside portion. Bottom was pretty good with 1/4 inch too.
Attached Thumbnails Supra Twin Turbo brakes install on SC430-img_1339.jpg   Supra Twin Turbo brakes install on SC430-img_1340.jpg   Supra Twin Turbo brakes install on SC430-img_1338.jpg   Supra Twin Turbo brakes install on SC430-img_1343.jpg
Old 09-03-14, 03:13 PM
  #52
416tt
416tt's Avatar
Not a problem,
Looks great ! So you need the spacer because of your wheels? Are they rubbing? And get extended thread lug nuts for a tighter hold. I got 20 from eBay for around 30$, they should be 25$ for you, the shaft goes right into the wheel holes.
http://pages.ebay.com/motors/link/?nav=item.view&id=250976264918&alt=web*
Old 09-03-14, 04:43 PM
  #53
fj40ih8mud
fj40ih8mud's Avatar
Yes, I have aftermarket rims, but there was clearance issues still. I put 1/8 washers on for test and had clearance barely. Worried that when they got hot it might be an issue, so I decided 5mm would be plenty.
With the 9mm spacers that I was able to get locally, that I have on termporary, I was able to put 5 full rotations of the lug nuts on.
I was assuming that with 5mm I would be able to put 8 threads on, which seems reasonable, but $30 is not very bad insurance. Just followed your link, for my rims, I need the stepped washer style lug nuts. will do some searching on ebay.
Thanks,
Old 09-03-14, 08:19 PM
  #54
416tt
416tt's Avatar
Thanks,
Ohh ok yeah good idea with spacer. And if you have no luck finding lug, I know gorilla makes the stepped washer style mags.. anyhow good luck
Old 09-07-14, 08:23 AM
  #55
fj40ih8mud
fj40ih8mud's Avatar
Wow! Gotta say that I did not think the stock brakes were that bad. I always stopped when I needed to.
Now, I can stop on a dime. Amazing upgrade. As much power as we have to speed up, these now bring the needle down quick!
This feels and looks like the brakes that you expect in a go fast car.
Thanks for the help on the upgrade, and I highly recommend that you do this upgrade.
I got all the parts on RockAuto, and was in the $300 range plus a bunch of dremel disks getting the calipers cleaned up plus $100 for powercoating.
Old 09-07-14, 09:12 PM
  #56
416tt
416tt's Avatar
Great, you got em on! To be honest they have already saved me a few times. For the weight of this car I would highly recommend it also and best part is that it's an OEM upgrade
Old 09-08-14, 08:48 AM
  #57
photalian
photalian's Avatar
Gotta say... the mk4 Supra is the quickest 60-0 stopping car I've ever been in, as a passenger. My friend scared the crap out of me once as we were approaching a red light going about 80 one fine evening on the turnpike. I think I was 18 years old at the time... man time flies.
Old 11-08-14, 03:47 PM
  #58
MrSC430SD
MrSC430SD's Avatar
Default Nice!
What camber kit did you used for the rear?
Thanks
DarKnight
04-03-07 12:03 AM
1stgenGSb
GS - 1st Gen (1993-1997)
03-18-07 08:45 AM
dohc3ltt
SC400 / 300 Classifieds
05-04-05 08:27 PM
pdykinga
05-27-03 11:43 AM
BLiu
Suspension and Brakes
08-13-02 04:57 PM
Quick Reply: Supra Twin Turbo brakes install on SC430
