SC430 wheel fitment
#91
I'll verify the info again once I put my new wheels on.
anyway, stretched tire should look more like these below.
both cars are on the the same wheels.
1st pic sc430, 2nd pic ls430
#93
I am thinking about putting some wider wheels/tires on my SC430 soon, I just checked out the available space inside the wheel wells, boy the rear wheel wells are hugemongous, looks like I can stuff a 345 in there if I want to.
My last car was a 04' STi, man that wheel wells was tiny
I think I am just gonna do some 295s, conservative and easy fitment, no rubbing so no headaches
#97
Thanks again!
Wow, I really am in love with that look, please post all the pics you have with this car, pleaseeeeeeeeeee
I am seriously going to look into doing the same, my preference is OEM wheels, I was just going to run my 06'+ OEM wheels with the liquid graphite middle piece, but the 18s does look a tad small sometime, this 19" ISF wheels looks perfect!!
Here is my car with the spacers on, I am going to lower it soon, don't worry
#98
Many SC430 members may think if using the oem wheels from an is-F that has more hourse power and bigger wheels, then the fitment must be very aggressive for the SC430.
Well...here is the moment of truth
IS-F wheels
Unfortunately, the fitment is as weak as your stock wheels.
oh well, the rear wheels do stick out 1mm more if you are that picky. haha
IS-F wheels
Not much, but is a little
#100
Thanks again!
around 1mm gain from IS 350 wheels and 3mm gain from IS-F BBS wheels.
IS350 (25.4/4)-5= 1.35mm, IS-F (25.4/2)-10=2.7mm
lowered + spacers.
#103
I kind of revised the Rominl's wheel fitment guide.
Knowing most members here don't buy custom wheels, it is more practical to show you a range of offsets for a given width that will fit the SC430.
Assume members want a better wheel fitment when they decide to get rid of their oem wheels, so +45 would be the highest offset for any given wheel width below.
When you shop for a new set, try to choose an offest that is close to the lowest number in the specified range in order to get the best fitment.
That is, the LOWER the offset, the MORE aggressive the wheel fitment for a given width.
I keep mentioning width and offset at the same time since both are needed in order to determin the lateral, or side to side, position of the wheel.
The wheel spacer fitment info is added for your reference.
For example, the fitment of 9.5" +30 in the front would look like adding 33mm spacers to your oem wheels while 9.5" +35 would look like adding 33-(35-30)= 28mm spacers.
Also, the setups recommended below should require no fender mods or stretched tires.
SC430 stock wheel fitment
Recommended aftermarket wheel fitment
IS-F wheels
IS-F wheels + wheel spacers (front 20mm, rear 30mm)
With spacers, the fitment is still conservative.
IS-F wheels
Can anyone assist me in changing my front-side light reflector to red. I want to match the red rear reflector. So that both the rear and front reflectors match. RED
#105
Ok, so I'm way new at this and was wondering if.. these will fit. According to the chart that Rominl posted it will, but I just wanted to know if it will sit close to "flush"? (I'm assuming that flush means everything lines up)
20 X 8.5 +20
20 X 10 + 25
Thanks for bearing with me lol.
20 X 8.5 +20
20 X 10 + 25
