SC430 wheel fitment
Old 01-03-11, 07:54 PM
  #151
cyberlexus
cyberlexus's Avatar
Originally Posted by Z3NK1
Spent my whole lunch playing with this at work haha, cool link!
me too haha
Old 01-03-11, 08:00 PM
  #152
cyberlexus
cyberlexus's Avatar
my imaginary SC430
Old 01-03-11, 08:22 PM
  #153
mandyfig
mandyfig's Avatar
Really nice. Black is a classic color.
Old 01-14-11, 04:19 PM
  #154
BLAQ ICE
BLAQ ICE's Avatar
Cool Spacers
I think a good outlook for SC owners looking to get the perfect fit for their aftermarket setup is for members who know a lot about this topic to post a chart stating what size spacers are needed given the set up stats.
Ex.
Vehicle Model SC430
Wheel Diameter (F) 19 (R) 19
Wheel Width (F) 8 (R) 8
Offset (F) 45 (R) 45
Spacer Width Needed for alignment just under fender :
(F) ?mm (R) ?mm
Thoughts???
Old 01-14-11, 04:20 PM
  #155
mandyfig
mandyfig's Avatar
Plus 2 ^^ I still need to know what spacers to use.
Old 01-14-11, 08:19 PM
  #156
Z3NK1
Z3NK1's Avatar
Perhaps you're looking for something like this. It's been posted a couple times in this thread already, and is a good starting point for anyone looking to get aftermarket wheels.
You can thank talwang.
Old 01-15-11, 03:43 PM
  #157
BLAQ ICE
BLAQ ICE's Avatar
It's not exact....Looking at the illustration it says 8 inch width + 45 offset 33mm to 0mm. That tells me that I can purchase spacers anywhere between 33mm to 0mm.
I was looking for exact measurements from just inside the fender of an SC430 front and rear. The illustration doesn't do that.
Old 01-20-11, 02:48 PM
  #158
grabber2
grabber2's Avatar
Originally Posted by talwang
Recommended aftermarket wheel fitment
Exactly what I want!!!!! What offset can I archive that or close to the above!!
I'm thinking going 19x9.5 with 255/35 all around but available offset are only 25mm or 40mm
Link of the wheel
Will the 40mm be fine? Cuz according to the chart, 40mm on a 9.5" is like putting a 23mm spacer to the stock. I really want to get something close to that picture above!!
Old 01-20-11, 04:24 PM
  #159
mandyfig
mandyfig's Avatar
I love the look of that offset. Nice.
Old 01-26-11, 07:56 PM
  #160
bacardi
bacardi's Avatar
talwang
430sc how will the Front 18x9 +35
Rear 18x10 +38
how will this setup work?
245x40x18 Front
265x40x18 Rear
Regards
Old 02-22-11, 01:52 PM
  #161
grabber2
grabber2's Avatar
According to the chart, the result of the following setup is:
Conservative:
Front - 19 x 8.5 offset 35mm (stick out 16mm vs factory)
Rear - 19 x 9.5 offset 40mm (stick out 24mm vs factory)
Aggressive: (btw - vendor states this setup won't fit the sc430??)
Front - 19 x 8.5 offset 20mm (stick out 31mm vs factory)
Rear - 19 x 9.5 offset 25mm (stick out 39mm vs factory)
If I use F: 235/40/R19 & R: 265/35/R19, would it rub if before lower & after lower 1.5"~2" ??????
I don't want to put 245/35 & 285/30 due to too thin for pole holes in NYC.....
my second option is 19 x 9.5 offset 25mm all around with 255/35/R19 <-- see member with this setup and looks good
TitanG545 (07-14-20)
Old 02-25-11, 01:36 PM
  #162
Gixxerboy6
Gixxerboy6's Avatar
Default Car has been sold...
I recently sold my car, but kept the wheels. If you like them, they can be bought for easy money on ebay right now... check them out!
http://cgi.ebay.com/ebaymotors/ws/eB...%3AMESELX%3AIT
Originally Posted by Gixxerboy6
I recently bought TSW Londrina chrome (staggared) and here's a look...
My setup;
Front 20x8.5 ET20
Rear 20x10 ET25
Old 02-25-11, 01:43 PM
  #163
Gixxerboy6
Gixxerboy6's Avatar
[ATTACH][/ATTACH]
Conservative:
This setup will absolutely fit without any rubbing issues using the stock suspension settings ...even if you go to 20"
Attached Thumbnails SC430 wheel fitment-small-londrina-6.jpg   SC430 wheel fitment-smalllex.jpg   SC430 wheel fitment-small-londrina-7.jpg
Old 02-28-11, 12:34 PM
  #164
mandyfig
mandyfig's Avatar
Ballain what kind of rims do you have now? Twisters? Pie plates?
Old 03-02-11, 05:08 PM
  #165
a1is4bits
4th Gear
a1is4bits's Avatar
Default My wheel setup
Pretty darn conservative at stock height.
20X 8.5 front - 235/35 ZR20 TOYO Proxes
20 X 10.0 rear - 275/30 ZR20 TOYO Proxes
Will go with 285/30 ZR20 on rear when time to replace tires.
Quick Reply: SC430 wheel fitment
