SC- 1st Gen (1992-2000)
Tips to unplug gauge cluster?
Old 04-26-15, 07:16 PM
GISguy
GISguy's Avatar
Default Tips to unplug gauge cluster?
Unplugging the cluster on my '95 seems near impossible as the three connectors are really on there tight. Is there a trick to getting them off? I've got a whole pack of LEDs waiting to go in.
Also, does anyone know what pins on what harness can be used to power up (with 12V I assume) and turn on the needles? I have a spare cluster from a '92 and I might switch a needle or two in case the other one is still fully lit. It would be convenient to use a computer power supply to put the cluster on a test bench and figure it out, but none of the threads I've found in search seem to help.
Old 04-26-15, 10:15 PM
t2d2
t2d2's Avatar
I tried pulling and prying with everything I could and never succeeded in disconnecting mine. I felt like any more effort would have resulted in significant damage. They're in there so tight, the plastic parts of the plugs were starting to crack from prying them out while depressing the tabs.
Old 04-27-15, 07:43 AM
jennie
jennie's Avatar
Press the tabs down with a flathead. The trick is to make sure there's some slack on the harness when you're pressing on the tab.
Old 04-27-15, 07:49 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
Just make sure the steering wheel is all the way down and out. If your tilt steering doesn't work, you'll have to fix the tilt mechanism before removing the cluster. Otherwise, get a pointy tool and push in and pry...
Old 04-27-15, 10:09 AM
CatManD3W
CatManD3W's Avatar
I used needle nose pliers to grab ahold of the plug and press down the clip at the same time....The first time they are a little difficult to get out but after that it is a little easier...
It is literally impossible to get them out by hand....
Old 04-27-15, 10:52 AM
Ali SC3
Ali SC3's Avatar
tiny screwdriver and push down on the plug. way too difficult to get them out by hand. needle nose pliers sound like a good idea also but try not to crush the plug.
Old 04-27-15, 06:03 PM
mikef
mikef's Avatar
yup, a small flat head, I was fighting with mine for a while before I used a tool.
Old 04-27-15, 07:00 PM
Tabaka
Tabaka's Avatar
The first time you take those plugs off is a PAIN! After the first time, it's much easier.
Old 04-28-15, 10:22 AM
BlackIRON
BlackIRON's Avatar
flat head and some slack in the wires is the best advice i can give lol.
Old 04-29-15, 02:23 PM
6SOARER
6SOARER's Avatar
First time I tried getting those plugs off were a pain. With a little help from this guy, made life a lot easier
t2d2
07-31-14 08:59 PM
gabzor
05-11-13 01:34 AM
heavy wate
04-03-03 06:44 AM
Dave Walker
01-11-02 09:52 AM
Quick Reply: Tips to unplug gauge cluster?
