power steering leak on line that goes from gear box to rack
Old 04-26-15, 08:14 AM
Sneezin300
Sneezin300's Avatar
Default power steering leak on line that goes from gear box to rack
So one of the 2 lines that go from the gear box to the pass side of the rack broke last night. I have been searching all night for if I can buy this line or? Can I use a splice connector like you would use to splice 2 sections of brake line together?
The line that broke is the one circled below.
Old 04-26-15, 01:01 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
https://www.clublexus.com/forums/sus...well-alot.html
^^ DIY for rebuilding the rack. I didn't see anything pointing to a new replacement of that line...it's either buy used or another rack.
Moved thread to maintenance.
Old 04-26-15, 03:42 PM
eknine9
eknine9's Avatar
Never heard of a replacement line for that. I couldn't give you a reason not to try the splice connector, worst case scenario you have to buy a new rack anyways. I'd just hate to see the splice connector fail while you're driving at speed.
How does the steering respond with that line broken by the way? Does it just turn one wheel while the other kind of follows the road, what happens?
Old 04-26-15, 03:58 PM
Sneezin300
Sneezin300's Avatar
It seems to turn like any car with no ps. I have been driving it just fine. It's just hard. I lifted the front end and both wheels turn with each other perfectly. Pump is not whining and is almost empty. Will be ordering a new rack soon
Old 04-26-15, 07:08 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Rack will run you around 300 bucks BUT with a core of over $100 so return that old rack!!
Old 04-27-15, 08:18 AM
Sneezin300
Sneezin300's Avatar
The line is 57 bucks.....I placed my order as there was on 2 left in the vountry!!!
Old 04-27-15, 01:49 PM
Ali SC3
Ali SC3's Avatar
steering will just be harder. some have even reverted the rack to non power steering for track use.
while the power steering is not needed for a manual rack, you may want to leave the fluid in it not sure if it also acts as lubrication in there, so I prob wouldn't let it run dry. plug it or something till you replace it.
Old 04-27-15, 01:58 PM
Sneezin300
Sneezin300's Avatar
Yeah. I have fluid in it now. The Co pressing fitting is holding for now temp. Until my line comes in
Old 04-27-15, 02:19 PM
eknine9
eknine9's Avatar
For future reference can you name the site/company that sells the line that broke? This is good information.
Old 04-27-15, 03:41 PM
Ali SC3
Ali SC3's Avatar
it looks to just be like a metal brake line type things with a banjo fitting on one side and a regular fitting on the other, if you knew the ends and the lengths, you could just make a custom line, but $57 is not bad at all.
if the repair is working and not leaking, then just keep an eye on it.
Listers
GX - 1st Gen (2004-2009)
01-18-17 05:45 AM
jim7485
11-30-15 04:28 PM
ICONYQ
Suspension and Brakes
02-03-09 01:01 PM
redhawks2
06-19-07 10:28 AM
AzSc4
12-22-06 09:48 AM
Quick Reply: power steering leak on line that goes from gear box to rack
