2jzgte vvti turbo drain??
I already know I'm going to get smoked for this but I've been searching for what I need to buy exactly for my sc300 with a 2jzgte vvti swap with stock turbos. I already purchased a an-10 flange to weld onto the oil pans but what else do I need? I know driftmotion carries a lot of this equipment but I can't seem to find out which hoses and fittings I need to buy. Help is much appreciated I want to get this thing finished.
ok so why does everyone say I need to buy a an-10 flange and bolt it to the oil pan? i was kind of confused when buying this flange because the factory y has two ports for the oil drain
yeah its just a tee of the appropriate size, and then use NPT to -AN adapters or NPT to hose barb ends for rubber hose, unless they actually have a -AN tee that would be nice. like aeroquip makes a 3/4 npt tee
the stock part shown above is nice though if you can your hands on one but you can replicate it possibly and you may want to use more of a "Y" fitting than a Tee fitting I just didn't have the time to find one online they have them all over the place for like fuel lines coming together etc..
Eaton Aeroquip 2092-12-12S Steel Pipe Fitting, Run Tee, 3/4" NPT Male x NPT Female x NPT Female: Industrial Pipe Fittings: Amazon.com: Industrial & Scientific
djkevin510
Performance & Maintenance
01-22-10 12:59 PM
