SC- 1st Gen (1992-2000)
1jz question
Old 04-22-15, 09:08 AM
Dtaylor3
Dtaylor3's Avatar
Default 1jz question
Bought a 1jz from jdmenginedepot. Only issue i can see with it is this.<br/>Anybody kno what connector this is?<br/>Sorry for the awful pic
Old 04-22-15, 11:28 AM
CatManD3W
CatManD3W's Avatar
Those are body plugs...i.e plug in at lower passenger kick panel
Old 04-22-15, 11:29 AM
SC2JZ300
SC2JZ300's Avatar
I concur /\
Old 04-22-15, 01:27 PM
Dtaylor3
Dtaylor3's Avatar
Preciate the reply... That is where the ECU is going, so is that going to cause a problem when i start my install? I have to get this done in 2 days so any setback would be awful. Out of the whole wiring harness those were the only ones cut
Old 04-24-15, 05:07 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Did you get it ran and working correctly?
Old 04-25-15, 07:27 AM
Dtaylor3
Dtaylor3's Avatar
I will be starting the swap next weekend when I'm off. Still confused about the body plug, because I have all the plugs in the ecu
Old 04-25-15, 10:42 AM
adc27
adc27's Avatar
Doesn't plug into the ecu...they plug into the car down by where the ecu goes
Old 04-25-15, 01:56 PM
Dtaylor3
Dtaylor3's Avatar
I'm guessing there is no way to kno exactly what it plugs into until I start the swap?
Old 04-26-15, 03:38 PM
CatManD3W
CatManD3W's Avatar
Once you remove the old harness from car you will be able to compare then....the plugs dont go into the ECU....they go into the lower passenger kick panel like I noted above
Those body plugs can only go in one spot...they are color coded and you just match them up....its not really that confusing...
Old 04-26-15, 10:44 PM
emoFTW
emoFTW's Avatar
Take your time. I can almost gurantee you it's going to take longer than two days. You will run into a lot of little issues. Have you extended your harness?
Old 04-27-15, 07:57 AM
Dtaylor3
Dtaylor3's Avatar
I have not extended the harness... I see a lot of people saying you can re position the ECU so you dont have to do that
Old 04-28-15, 11:52 AM
estomax
estomax's Avatar
yeah you can put your ecu where the carbon canister goes but u will have to extend the body harness plugs to reach the kick panel still
Old 04-29-15, 12:16 AM
Dtaylor3
Dtaylor3's Avatar
I kno... Probably get that done Friday night... The knock sensors are on the ecu right?
Old 04-29-15, 12:23 AM
Dtaylor3
Dtaylor3's Avatar
Could I reuse a body plug connector from the 2j if I cut the one I need?
Old 04-29-15, 07:16 AM
estomax
estomax's Avatar
you can re-use the 2jz body plug sure, but if the 1jz one already matches just keep the 2jz harness in one piece, it's worth something..
on my car i went full frankenstein cause i had an sc400 and a chaser 1jz VVTI so i had to take an sc3/400 body harness and do a complete splice into the 1jz vvti... that was a good bit of work.
start with getting the engine into the car.. you got a ways to go yet..
Quick Reply: 1jz question
