SC- 1st Gen (1992-2000)
Is it possible? 28.8 mpg?
Old 03-08-15, 11:09 AM
SaintLexus
SaintLexus's Avatar
Default Is it possible? 28.8 mpg?
I've never really bothered about the mpg before until today. So far I've driven 144 miles approx. refueled and it was just 5 gallons to fill up and the math having these numbers gives me 28.8 miles per gallon. Typical so. Cal speed is what I'm doing. I have a stock 5 speed 1997 sc300.
Old 03-08-15, 02:59 PM
Sweatshop
Sweatshop's Avatar
I believe its possible. On my long runs from Va to Al, I averaged 27mpg in my auto SC4. But everything has to be PERFECT. No lead foot, no a/c and optimal weather conditions. The car has to be in tip-top shape too especially with regards to tire balancing and pressure. Other than that, 23mpg in mixed driving is the most I ever see.
And you have to use every drop of gas before the next fill-up....and that practice strains the fuel pump.
Old 03-08-15, 03:38 PM
SaintLexus
SaintLexus's Avatar
Default Average mpg
Here's my result 306 miles/11.10 gallons =27.56 mpg. No ac... I did hit a lot of elevation. That's to say from sea level to higher grounds. I started in San Diego heading to San francisco. 😊
I find it quite hilarious that Im reviewing a car that's almost 20 years old.
Hope this helps though.
Old 03-08-15, 05:08 PM
ems
ems's Avatar
I think that's spot on, I drove from mpls to austin tx in a gmc savana high top averaging 65mph driving modestly and hit 26mpg average so an aerodynamic car driven modestly should do better than that at least, this summer I will try for 30mpg. I think it's possible even if you **** off traffic driving -10mpg on the highway. Ha
Old 03-08-15, 05:24 PM
Biddles
Biddles's Avatar
The best I got was 415 miles on a full tank. The gas light wasn't on when I filled up again though. I would say it was 90% highway mileage.
Old 03-08-15, 09:01 PM
Shayy
Shayy's Avatar
I have the same car as you and I've gotten 29 average, but that was nearly 100% highway miles. I was on a road trip. I think I could maybe get closer to 30 if I was on stock wheels.
Old 03-09-15, 07:32 AM
mak89
mak89's Avatar
My past 99 sc400 would get city 25-27. This was based off my mpg indicator on the cluster which I found the feature couple weeks before selling. Never had a chance to properly check average by refilling but stayed consistent around that range.
Old 03-09-15, 08:31 AM
Studiogeek
Studiogeek's Avatar
VVTI is amazing! I get about half that in the city.
Old 03-09-15, 09:20 AM
t2d2
t2d2's Avatar
Same here. I tell myself it's one of the few things that keeps the price of entry from being high with these cars.
Old 03-09-15, 01:54 PM
Ali SC3
Ali SC3's Avatar
the 5 speed auto and lower rear and gear ratio the vvti 1uz got goes a long way with those mpg's also. vvti sc300 didn't get it which is annoying cause once you drive one you will want it first gear on the 5 speed makes it feel completely different.
Old 03-09-15, 03:47 PM
michaelb20
michaelb20's Avatar
I haven't calculated my car's MPG personally, but I know that when I first bought my SC 300 the display in the cluster said the average was 23.2 MPG. It was previously driven by an older lady in the LA area, so considering the traffic in LA is terrible and assuming you didn't encounter much traffic, 28.8 MPG seems plausible.
Old 03-09-15, 03:59 PM
BeaksSC
BeaksSC's Avatar
When I normally fill up, my odo is between 220 and 250 miles and it normally take 15 gallons to fill. And thats normally when my gauge is right above the e bar
Old 03-10-15, 12:04 AM
KahnBB6
KahnBB6's Avatar
Received 1,250 Likes on 870 Posts
It beats my best figures no contest (~21mpg highway but with considerable luggage last I measured). But that's amazing considering your final drive ratio is still 4.083.
Old 03-11-15, 08:36 PM
Asha'man
Asha'man's Avatar
When I first bought my car in Phoenix, I drove it home to Denver and of course checked mileage. Filled up in Meteor Crater, AZ and then again in Las Vegas, NM, which hand calculated to 27.5mpg. I was doing 80 with the cruise on and the AC for a lot of it. Aerodynamics, weight and a powerful engine not working hard are all good for mileage.
Old 03-11-15, 08:39 PM
Asha'man
Asha'man's Avatar
Lol, looking at it, 27.5 is almost sad compared to my daily driver Jetta TDI, which gets 46mpg mixed driving pretty much all the time. Still, for something as large as the SC, high 20s isn't bad.
Quick Reply: Is it possible? 28.8 mpg?
